Helped needed deciphering my engine id code...
Old Apr 29, 2003 | 02:02 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Just located my engine id code and would like some help deciphering it. The code is as follows:
A910606CFA
I've tried looking up articles on the web for this and have only found VIN deciphering codes, I hope you guys can help, thanks.
Old Apr 29, 2003 | 05:43 AM
pasky's Avatar
I forgot to mention my main goal here. I recently purchased this 1991 Camaro RS and I was told it isn't the original and engine and can pretty much see that, however I was told this was a 4.3 litre engine and have no clue where this thing came from or whether its true. Now I have the engine ID from the engine, is there any way to get a VIN number out of this, or is there a VIN number on the engine so I can match up what is already on the car? Thanks.
Old Apr 29, 2003 | 07:25 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
a 4.3? really? can you post some pics? What's the 8th digit on your vin? if you have an RS camaro I'm guessing it's "T". You can call any GM dealer parts department and give them your engine ID number and they will run it for you to tell you what's under the hood. Hope that helps you some.
Old Apr 29, 2003 | 01:16 PM
pasky's Avatar
Great thanks, i'll be sure to get some pics up soon, let me go ahead and call the dealer later today. The original Engine was a 3.1, however whats under the hood is not the original so im pretty sure the VIN won't match. I'll be sure to find out today though and thanks.
Old Apr 29, 2003 | 02:00 PM
pasky's Avatar
Just called my local chevrolet dealership, they were unable to help me identify this engine , any other ideas?
Old Apr 29, 2003 | 05:28 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Post some pics of it and we will see if we can identify it.
Old Apr 30, 2003 | 05:59 PM
pasky's Avatar
Here are some pics of the engine.
Attached Thumbnails Helped needed deciphering my engine id code...-mvc-001f.jpg
Old Apr 30, 2003 | 06:00 PM
pasky's Avatar
Attached Thumbnails Helped needed deciphering my engine id code...-mvc-007f.jpg
Old Apr 30, 2003 | 06:03 PM
pasky's Avatar
and another
Attached Thumbnails Helped needed deciphering my engine id code...-mvc-008f.jpg
Old Apr 30, 2003 | 06:04 PM
pasky's Avatar
another
Attached Thumbnails Helped needed deciphering my engine id code...-mvc-003f.jpg
Old Apr 30, 2003 | 06:05 PM
pasky's Avatar
And finally the actual car.
Attached Thumbnails Helped needed deciphering my engine id code...-mvc-009f.jpg
pasky's Avatar
Ok folks, I delivered, can anyone tell me what it is, although i would definatley rather go by the Engine ID.
Old Apr 30, 2003 | 06:15 PM
pasky's Avatar
Once again, for people too lazy to scroll back up, the engine ID # is:
A910606CFA
Old Apr 30, 2003 | 06:28 PM
bigals87z28's Avatar
Car: Check The Sig
um, that looks like a 3.1L to me. thoes engines are 60* where the 4.3 is a 90* block. sorry to disapoint you
Old Apr 30, 2003 | 06:40 PM
pasky's Avatar
Where is the disappointment? I just want to identify the engine. I don't ecactly understand what you mean about the degrees or angles but its no big deal my main concern is because im going to do a rebuild on it soon and is the reason of me asking, thanks for the help though any other opinions? I love the way the car runs. Could somene possibly circle my TPS unit?
Old Apr 30, 2003 | 06:50 PM
Car: Check The Sig
TBS? you mean TPS? The degree is the degree of the engine block.. Chevy V-8s for the most part at 90* as are some V-6's. The 4.3 is a 350 with 2 cyl. lopped off. The 2.8/3.1/3.4 are all 60* V-6's. The intake you got there is for a 60* block, and would not fit the 4.3. most 4.3's are tbi, but there is this 4.3 vortec block that has something that looks like TPI.. hers a pic... its of my brothers truck.
Attached Thumbnails Helped needed deciphering my engine id code...-mikes-engine-small-.jpg
Old Apr 30, 2003 | 06:52 PM
vwdave's Avatar
1. Why is this in the TPI board? The V6 would probably be more help.
2. The "Degrees" he was talking about refers to what angle the pistons are to each other when looking from the front.
Old Apr 30, 2003 | 06:55 PM
Car: Check The Sig
yea, this should be in the 6cyl board... oh well... just wanted to help
IROCZ1989
Jan 24, 2016 03:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
