Ported my plenum, heres the video
Old May 2, 2003 | 09:37 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
This was my first plenum porting job ever. tell me how i did and be harsh i need to learn. personally i think it came out good, i didn't hog out the ports or take off any "extra" metal i just sort of removed obstructions and tried to smooth everything out. doing the intake next...
get the video here:
HttP://www.geocities.com/kingtaling/plenum.wmv
right click, save as. sorry for low quality, geocities max upload is 5 MB...
I used a carbide cutter tip for the die grinder, and dipped it in gear oil constantly. to smooth it out i used a dremel with a stone, a sanding paper, and a wire brush tip, in that order. then i lightly bead blasted it.
Old May 2, 2003 | 09:38 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
for some reason geocities wont take my darn video!
ah, well if anyone wants a copy i can email it...
sigh* or if anyone has a better idea for hosting a video or pics... i could post the pics here i suppose.
Old May 3, 2003 | 09:34 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
send me a good quality one to this email address (less than 15 megs)
jbadget@uark.edu
I'll host it and put a link for you.
Old May 4, 2003 | 03:18 AM
Car: 1987 GTA
Transmission: 4L60e
As promised, the video.
Nice work by the way....
Right Click "Save Target As"
Old May 4, 2003 | 02:13 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Looks smooth. I bought the 90* angle head for my dremmel to get into the runner holes and really flatten out those walls...
It's pretty easy to gasketmatch the openings too while the plenum's off and the dremmel's runnin'...
Old May 4, 2003 | 02:39 PM
bigals87z28's Avatar
Car: Check The Sig
wow.. i just rememberd that i have that extention wire for the dremmel! wow.. how come i didnt think of that before? oh well.. going home this weekend cause college is done with!... till sept.
edit: ok just watched the video, and what is that white ball thing that you used? and that wire brush looked like it did an awesome job! looks like i gotta get back to my plenum. Ill post a picture of what i did so far.
Old May 4, 2003 | 07:47 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
thw white ball is just a stone tip for the dremel. i had like 10 so i figured i would test them out to see what they did. it was good for smoothing out the original carbide cuts which were not very smooth at all. then sanded it to make it a bit better (dremel sander thing) then the wire brush to make it real smooth.
also i didnt have a 90* anything to get inside the runner ports so i just did as best as i could with the carbide cutter tip and went in sideways. thats why the metal in the middle comes to a sharp point, but i think that wont hurt airflow at all.
I just started my intake manifold, matching it to the gaskets...
wow the intake ports are WAY off from the gaskets. theres a good 1/4" of metal that needs to be removed from each port on both sides to match the gaskets! i cant wait...
heh should i mail that vid to you too?
and thanks for the appraisal!
Old May 4, 2003 | 08:06 PM
Car: Check The Sig
hum.. im gunna go looking for one tomorrow...
Old May 6, 2003 | 09:14 AM
wlsmoku's Avatar
Car: 1988 GTA
I like what you did around the runners!! Just my opinion, but the holes where the throttle body don't look round anymore...it looks like the dremel gouged into it a bit, and you smoothed it out...am I just seeing things?? I probably am. here's a pic of mine...I thought you might want do an added mod to help smooth things out a bit. I put "magnum Steel" in the pit areas where you ground out around the throttle body. probably doesn't make sense, so check out the pic. the filler is the gray stuff. You did a great job non the less
Old May 6, 2003 | 01:45 PM
Car: 1987 GTA
Transmission: 4L60e
I'll be able to host another video if you want. Just send it to me before Sunday. After that....I'm on slow dial up again and won't have access to my hosting account for a good while.
Old May 7, 2003 | 12:10 AM
383 rocket bird's Avatar
Awesome video, thanks
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
