36lbs injectors for 383?
Old May 7, 2003 | 11:45 PM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
Hi, I'm building a 383 with AFR 190's, and probably the LPE 219 cam. I have a superram, base, runners and plenum and a 58mm TB. Will the 36lbs injectors be too small? I also have the holley 255 lph fuel pump.
Old May 7, 2003 | 11:51 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
You will be fine with #36 they are enough....
/N.
Old May 7, 2003 | 11:55 PM
danzig27's Avatar
Car: 91 Camaro Z28
I'm sorry....what i meant to ask was if they were going to be too big. They're accel high impedence injectors.
Old May 7, 2003 | 11:57 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
You can get away with smaller! Either way you need a custom PROM. SVO#30 is a nice set of injectors and they are cheap too....
I recently put them on my engine but havent done any "driving" yet but my idle is good now ( after some PROM work...)
/N.
Old May 8, 2003 | 12:01 AM
danzig27's Avatar
Car: 91 Camaro Z28
Well, i'm picking the injectors up at a good price. I will the the car tuned and new chip burned by Cerra Racing in Illiniois. So i'm not too worried about that. And if not, i have acess to the programs and the tools needed to do it myself. Will the hurt me at all being that big? Or is it kinda like the 58mm Tb and the 52mm Tb.....where you can use the 58...and it won't hurt you...but 52 would have been adequate also. Thanks!
Old May 8, 2003 | 12:05 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I have no tuning experience when it comes to #36 on a 383 engine so I can give you an answer, but I'm sure someone else will answer. My guess is It will be harder to tune (atleast at idle) with #36, but my guess......
/N.
Old May 8, 2003 | 06:40 AM
Doug Flynn's Avatar
I've tuned 383's with 36's with aftermarket controllers, batch fire, with no problems.
Old May 8, 2003 | 08:13 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I know this is not the same as your engine, but I have a supercharged 305 TPI and I am running 30LBS injectors in it. The vehicle runs fine, it's all about the PROM.
Old May 8, 2003 | 09:50 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
36s would probably be overkill for a superram engine with that small of a cam. But you shoudl be able to get them to idle OK though if you want room to grow. Idle problems actually tend to happen more in HUGE cam engines, because the idle VE is so bad that the injectors simply cannot supply that little fuel.
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
