i need help my car doesnt start
Old May 8, 2003 | 11:27 AM
360Iroc's Avatar
just built a 350 to replace my 305
i seem to remember having the problem 4 years ago in my trans am.
i have compression, i have spark i have fuel pressure, it doesnt start.
one thing ive noticed is that now the fuel pressure drops instead of holding for hours in the guage like it used to?
i have flames coming out of the headers every now and then and a backfire a few times
i believe its 180 out but the expert swears it not
i have gone through wiring multiple times and cant seem to find anything
Old May 8, 2003 | 04:33 PM
360Iroc's Avatar
why would you read this and not throw out an idea?
makes no since
Old May 8, 2003 | 04:45 PM
Dirty Rob's Avatar
You have flames coming out of the headers and backfiring, but the car wont start? Maybe people were confused.
Old May 8, 2003 | 07:04 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I would guess your fuel pressure regulator is bad or leaking injectors cause your fuel pressure should stay up for a while...
Old May 8, 2003 | 07:16 PM
Ragtop89's Avatar
Could be:
The dizzy - it's 180 out. I've had this happen with almost all my rebuilds. Spin it 180 and see what happens.
Fuel Injectors are screwed - When I put my Accel 24 lb injectors in the O-rings on them BLEW CHUNKS - they wouldn't seal and I was dumping fuel into the intake and lost fuel pressure FAST once I stopped turning over the car.
Valves - I was that guy that OVER tightened his valvelash so that none of my cylinders had any compression. Stoopid, I know.
I also tried to start my car with my ECM power wire disconnected by the battery.
Another dumb move on my part.
Try looking at those and see what happens.
Old May 8, 2003 | 10:24 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Maybe nobody is replying because it could be pretty much anything. "just took car apart and rebuilt and now it doesn't work" is pretty vague, no? Maybe you didn't put something back together right? I know it's a reach, but ?
Old May 9, 2003 | 02:34 PM
360Iroc's Avatar
WELL ED ITS ALL EXPLAINED ABOVE
ACTUALLY IT WAS A VALVE PROBLEM
Old May 9, 2003 | 05:02 PM
Ragtop89's Avatar
So it runs now KDogg?
Old May 10, 2003 | 11:30 AM
360Iroc's Avatar
it runs thank for the help guys
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
