Throttle body bypass?
Old May 11, 2003 | 10:04 PM
firebirdkid's Avatar
Whats up. I ordered a TB bypass kit, but never put it on. Now that the weather is warmer, i think i'm gonna put it on. some one told me that its not good in cold weather. how cold is too cold to put it on? thanks.
Old May 11, 2003 | 10:57 PM
bigals87z28's Avatar
Car: Check The Sig
Hey, can i ask ya... how much did you spend on this "kit"... if you spent more then $8, then you overpaid... you could of done it with as little as $2... I used a heater hose coupler, and reused the clamps, and just reversed the hose going into the block. thats the Ghetto way, but you could of just got some hose from a parts store and you could of been done with it. anyway... heres a pic of mine..
Old May 11, 2003 | 11:32 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
What excatly is a TB-Bypass and what does it do? Thanks.
Old May 12, 2003 | 12:06 AM
Car: Check The Sig
When GM designed the TPI system, they ran into the problem of the throttle blades sticking because of cold weather starts. Water would freeze around the blades causing them to stick and sometimes freeze inplace till the car warmed up. Engineers created a path inside the tb so that warm engine coolant could pass through the tb to warm it up. The only problem with that is that now the tb is heated, which in turn heats up the incoming air and hot air aint no good. I did the tb mod, and i noticed a tremendious drop in the temp. of the plenum. Before, a 1hr drive would make the plenum very hot, to where now it is just a little warm, and you can touch it. Now members of this site that live in the coldest depths of Minn. and farther north have done this mod, and have not seen any sticking of the blades. This also serves as a very helpful mod by removing the coolant lines, that alows the removal of the tb to be a little easier. Its a good mod to just do if you just wana do something. Took me about 30mins to do mine, and most of the time i was thinking of a way to fit the two ends together. good luck and have fun with your car.
Alex
Old May 12, 2003 | 12:10 AM
Cool, Thanks for the info!
Old May 12, 2003 | 05:02 PM
llvll4l2c91350's Avatar
here's a close up of mine. my "kit" was dirt cheap and only included the coupler.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
