Power
Old May 14, 2003 | 08:31 AM
DarkKnight's Avatar
Power
Im new to this so bare with me...
I recently purchased a 1990 IROC-Z28 for 4K.
It has 79K with a 5.7TPI 350.
The car already has some mods...
3" Flowmaster cat back
Catco hi-flow cats
Accel cap and rotor
GM 8mm performance wires
Rapidfire plugs
BBK AFPR
K&N air filters
TB air foil
Ported plenum
I was told these cars can run mid 14s and high 13s with some bolt ons?
I was also told that putting in a ECM chip for a Corvette can drop it almost 1.5 seconds?? Is that true?
Old May 14, 2003 | 09:30 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Your setup right now, assuming it is in good tune and what gears it has, should run very low 14s. An aftermarket chip will help a little (some will disagree) but only about 2-3 tenths at the MOST in the 1/4.
If you plan on doing more mods then I would wait until you need a new chip then burn one for your application.
Old May 14, 2003 | 01:34 PM
Morley's Avatar
Re: Power
No, there were wiring differences in the 'Vette ECM's, the chip from a 'Vette won't work in an F body.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
