SLP box only install, need anything else?
Old May 24, 2003 | 07:00 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
i'm wanting to purchase the airbox only from the slp cai kit P/N: 21015.
do i need to buy anything else, like P/N: 21021 or P/N: 21017 to have it work on application (89 trans am). (these are extended wiring harnesses for the vac. can and MAF)
not sure where there's room for the vacuum canister or if the MAF is moved when just putting in the box.
anybody have some pix with just the box?
thanks!
- del
Old May 25, 2003 | 02:52 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You can relocate the vacum canister from the passenger side to the driver side near the battery. That is what you will need the wires provided with the kit. Once you do that you have to remove the metal base that the canister mounts to.
You don't have to relocate MAF. You may have to work to get the wires to stretch that far. I did. I did have to relocate some relays to get the box to fit right.
It's not that hard to do. Just a little time consuming.
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
BigJon88
Aug 19, 2015 10:09 AM
bryan623
Aug 10, 2015 11:33 AM
