TB boot pipe thing
Old May 28, 2003 | 10:28 PM
Garett92Z's Avatar
TB boot pipe thing
hey guys!
I am missing the pipe from the throttle body boot and the TPI airbox on my 1992 Camaro Z28 5.7 TPI. Could I just use some 3" PVC pipe or something????
Has anyone done anything custom? The wrecking yards around here want $40 for this pipe...
Thanks a bunch,
Garett
Old May 30, 2003 | 06:42 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
There is no pipe that i know of on the 90-92 cars. you have a boot and the y filter housing. you can get the boot new for less then 20.00. And the housings come up on ebay pretty cheap.
Good luck.
Old Jun 1, 2003 | 01:22 PM
Garett92Z's Avatar
there is a pipe. you have the TPI boot (which is about 4" long) then a pipe that runs from the boot to the y-filter-box-assembly.
Old Jun 1, 2003 | 01:51 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Sounds like your talking about a Maf setup. This is the stock box and boot on my 90 SD setup.
Old Jun 1, 2003 | 02:02 PM
kevinc's Avatar
Car: 1982 Z28
Wow, you evidently know something neither GM nor Helms know...both think there is a ~10.25" rubber bellows that connects the TB to the y-duct on '90-92 F-bodies.
You should share your "wisdom" with them so they don't keep spreading misinformation.
(guess the air really is thinner in Canada)
Old Jun 1, 2003 | 09:13 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Well it really depends if they're talking about a Camaro or Firebird. The air intake is differant on each I believe.
Old Jun 1, 2003 | 09:19 PM
Z_Ghost's Avatar
A pic of the stock setup can be found here.
https://www.thirdgen.org/techbb2/sho...hreadid=182395
Old Jun 2, 2003 | 10:13 AM
Vader's Avatar
Yes, the Pontiac intake tract is substantially different from the Chevrolet type. The lower nose and hood line precludes the use of the 'Y' pie/filter unit, and necessitated the battery reloaction to the left corner. The intake tract on a Pontiac is somewhat less restrictive than the 'Y' filter adapter, in that it is a larger round duct.
Old Jun 2, 2003 | 12:07 PM
kevinc's Avatar
Car: 1982 Z28
The guy's asking about a '92 Camaro.
I agree the 'Bird ducting is a nice design, can't figure why GM didn't just make it that way for both.
Yank the 'Bird filter can, install a K&N cone, and you're pretty much at the point of diminishing returns in terms of airflow.
However...for the Camaro there is only one published design and it's a ~10" rubber bellows that likes to collapse @ WOT when it's hot.
Old Jun 2, 2003 | 12:38 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Kevinc....Thats interesting about the boot collapsing. I will have to check mine for any problems.
Old Jun 2, 2003 | 03:10 PM
kevinc's Avatar
Car: 1982 Z28
I noticed mine @ the drag strip, my data captures showed the MAP values declining at high revs. I rigged up some bracing w/ zip ties, back to 100KPa the whole way down the strip and an accompanying improvement in MPH.
Old Jun 2, 2003 | 03:20 PM
91Z28-350's Avatar
bracing? You mean, just zip ties around the boot? That's interesting, I'll have to make a note of it. Thanks!
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86IROC112
Sep 7, 2015 01:37 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Rustyweb7
Aug 9, 2015 03:05 AM
