LT1 intake with large cap distributor?
Old Jun 2, 2003 | 11:32 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
LT1 intake/miniram with large cap distributor?
Do you have to change to a remote coil like with the Stealthram to clear the LT1 intake? What about the miniram?
Chris
Old Jun 2, 2003 | 12:46 PM
tpi_roc's Avatar
The remote coil is easiest, and as the intake is supplied from john necessary, you can however chop off the EGR blocks with some extra work to make the coil-in-cap distributor work.
I completed the LT1 intake install, I'd recommend just getting a remote coil distrib.
Old Jun 2, 2003 | 01:12 PM
ULTM8Z's Avatar
The MiniRam works fine with HEI large cap distributor. However, it needs the Corvette fuel rails to do it. I bought the Camaro fuel rails and had to grind off about .200" from the rear corner of the passenger side rail so I could rotate the distributor to change the ignition timing.
Old Jun 2, 2003 | 01:33 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks yall
Chris
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Jan 29, 2017 07:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
