ECM Interchange 730 and 749
Old Jun 3, 2003 | 02:09 PM
bennyhonda's Avatar
Car: 1992 Camaro RS
Does anyone know if the factory prom for a 730 will work in a 749? I did a search but everything is about modifying the 730 harness to use the 749 for turbo/supercharger use.
I purchased a complete sd tpi kit for my TBI -> TPI swap and it came with a 749 computer with a AXXB prom installed, the guy said it ran fine but I wanted to make sure it would work. Also, anyone know what kind of drivability to expect using the 305auto prom with a 305 5speed car? I think I read it tends to stall when coming to a stop? I'd like to install the TPI make sure everything works, then burn a 5 speed chip and start tuning.
Old Jun 3, 2003 | 02:14 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Provided the harness is pinned to match the 730 code.. it will work.
I have run both a 730 and 749 with the harness pinned to $58 SyTy code. It stands to reason the reverse is true.
Running auto code with a stick or vice versa is bad Karma. Many changes in IAC control...
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
