Stealth Ram install questions
Old Jun 16, 2003 | 06:17 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
For those of you that have already installed an HSR I have a few questions. When I was working on removing the engine today a couple of things came to mind. Will the coil be able to remain in the stock location? I already had to clearance it for the base for the old TPI setup. And where did anyone remount the MAP sensor? I know with both of these items it really doesn't matter where they are located, but I want someone to tell me what they found. Thanks in advance...
Old Jun 16, 2003 | 08:07 PM
JR305's Avatar
Well, I swapped from TBI to Stealth ram so mine may be a little different but I will tell you what I did. For the coil I just made a bracket out of sheet metal and mounted it to the firewall. As for the MAP sensor on a TBI car it is mounted on the top of the fire wall, I just left it there and ran a vaccum line. I can get a pic, but you will have to wait untill this weekend.
Old Jun 16, 2003 | 08:50 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Thanks for the info. I was looking at it some more tonight and figured to mount the MAP on the firewall like yours is. As for the coil, don't know where to put it yet...
Old Jun 17, 2003 | 05:06 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I just put the coil back where the factory had it. Fit just fine...although my bracket was already clearanced for a TPI Edelbrock base...but I do think that it will go in just fine without modifying...sounds like yours is mod'd already
Old Jun 17, 2003 | 06:48 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Yes I had to grind it for the TPIS base. I was looking at it tonight after I finished pulling the engine and I think it will fit fine. I also found a spot next to the evaporator housing to stick the MAP. Thanks for your responses...
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
