305 Knock Sensor in 355
Old Jun 17, 2003 | 01:45 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
When I swapped the motor, I just plugged in everything from the old block into the new one, So I am still running all 305 stuff except for the chip. My question is, what effect could running a 305 knock sensor have on my 355?
Old Jun 17, 2003 | 02:23 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
it could cause it to ping like a bastard because the 305 sensor is designed to be sensitive to a different frequency. A new one is only like $20.
Old Jun 19, 2003 | 07:37 AM
Spdfrk1990's Avatar
im going from a 305 tbi to a 350 tpi the 350 block i have is a 76 will the knock sensor work on it?? i have to have ir right
Old Jun 19, 2003 | 08:15 AM
Jim85IROC's Avatar
350 is a 350. The year doesn't matter. Just make sure you get the right one for your ECM. The speed density cars used a different knock sensor than the MAF cars.
Old Jun 19, 2003 | 08:35 AM
Spdfrk1990's Avatar
that good i want to use speed density where exactly does the knock sensor go. Thanx i have alot to learn about the newer engines still.
Old Jun 19, 2003 | 09:50 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
on the passenger side. on the older block just remove the drain plug for the block located right before the starter and after the engine mount. you can't miss the plug when looking from underneath. good luck!!
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
