edelbrock runners
Old Jun 17, 2003 | 04:49 PM
Pappa Smurf's Avatar
Car: 91 pro street camaro
Engine: F1r procharged stroker
Transmission: turbo 400 w/gearvendor OD
Axle/Gears: moser 9" 3.89 35 spline axles
edelbrock runners
Anybody else besides me having fit problems with their edelbrock baseplate & runners? I've had vacuum leaks at top & bottom of the runners. Dont seem to hear many people talk about having edelbrock runners on their edelbrock intake. Havn't used any gasket sealant, should I? Advice please!!
Old Jun 18, 2003 | 01:30 AM
centaur's Avatar
Car: 1991 GTA
My pal had horrendous problems with selaing the Edelbrocks on his 92 T/A ZZ3. He finally gave up and sold them and bought a Super Ram which is way better anyway.
I remember we tried so many different gaskets, the edelbrock ones were junk and so were the Accels.
Finally siliconed the **** out of them and they lasted two weeks.
The leaks were so bad the idle was at 1500 and the headers would begin to glow red hot, now that is leaning out!
They sure look pretty though
Old Jun 18, 2003 | 06:22 PM
Took the car back to the local speed shop that built and installed it(with 1yr warr) and so far they think it's an injector leak?? Doesn't make sence to me!
So far i'm not real impressed with them. But they have a pretty good rep around the area. Jury is out with me!
If the problem can't be solved Holley Stealth Ram may be next.
Thanks for the info!! (yes it's purty)
Old Jun 19, 2003 | 08:56 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
It makes pretty good sense if you ripped a rubber O-ring installing the injectors into the new base. That's a pretty big vacuum leak.
In my experience with three different gasket manufacturers, all of the TPI gaskets I've used are crap and must be treated with care while cursing, banging, and prying the intake pieces back together... or you'll rip one small edge and have to start all over again with a new $10 set of gaskets...
Old Jun 19, 2003 | 11:01 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
The fix is GM gasket maker, amazing stuff!!! I have sealed oil pans w/o a gasket wt that stuff. Definetly if an injector o-ring slip's up when you put the rail back in(if you took them out when installing the runners) it will leak. That is exactly what happened to me when I installed the SLP runner's.
Old Jun 19, 2003 | 11:20 AM
bnoon's Avatar
Yeah 91wtROH17's, I agree. Gasket maker is great stuff and is all over the surfaces of my intake gaskets too. The O-ring is pretty solid since he went a step farther than you did since he installed the base as well as the runners.
Old Jun 19, 2003 | 11:40 AM
Car: 91Z
I totaly forgot he said he installed the base and runner's!!l Thank's bnoon, I am really tired today.
Old Jun 19, 2003 | 11:00 PM
Got it back from speed shop tonight-no leaks now!! You people were right it was a o-ring torn and also a torn lower runner gasket.
Left the shop and got about a mile and it started running rough. Turns out 2 out of 8 injector connections weren't snapped down. I'm done with this place, too many other good shops in the area.
Thanks for the replies, Smurf
Old Jun 20, 2003 | 07:58 AM
Car: 91Z
Good to hear!!
Linson
Oct 24, 2025 02:00 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
