WTF injectors are these? PICS
Old Jun 17, 2003 | 10:27 PM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
OK i Posted about it before I bought this Iroc with 58K orignal miles on it but its obvious the head have been off and the injectors are not orginal..the guy who owned it before me did nothing to the car so.
Here is a pic of the injectors help me out!
Justin
Old Jun 17, 2003 | 10:33 PM
TorchTA's Avatar
oops
Old Jun 17, 2003 | 10:35 PM
TorchTA's Avatar
look lik the injectors in my 91 formy. go figure.
dunno what they are either
Old Jun 17, 2003 | 10:47 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Those are the Multecs that were used on the later ('89-'92) TPI engines and even early LT1 motors.
They are not considered good. Just do a little reading.
https://www.thirdgen.org/techbb2/sho...ltec+injectors
Old Jun 17, 2003 | 11:16 PM
llvll4l2c91350's Avatar
would it be a good idea to change 'em on my car?? its a 91 formula 350 with the same type of injectors. but i've read a lot of threads now about how unreliable they are. car seems to run fine but,,,dunno how long i have before the injectors go bad.
Old Jun 18, 2003 | 01:17 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Check the resistance on them to see if they are still in good shape. If so then I wouldn't pull the plenum and runners just to replace them.
Old Jun 18, 2003 | 09:10 AM
MdFormula350's Avatar
i have those injectors also, maybe time for a change then, i might have to get the trusty ohm meter out.
Old Jun 18, 2003 | 02:19 PM
85rocker's Avatar
GM multec injectors = trash. end of subject.
the windings/insulation are made of material that gets eaten by the materials in gasoline. simply a matter of time before they fail. worse design ever. when they do start to fail they will look like ignition, O2, TPS anything else but injectors. you'll spend alot trying to figure it out. replace them they are sh*t.
Old Jun 18, 2003 | 05:19 PM
so would it be better to retain the stock setting of 22# with new injectors or get ones with higher rating? my motor is mostly stock although i'm plannin to get the base ported or siamesed and buy some slp runners next week. i'll still have the stock chip in there. i hear Accels are the way to go, but am not sure about the lb rating.
Old Jun 18, 2003 | 07:01 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
If you don't plan on doing any major mods then you're best to stick with the stock size
stalkier
Dec 6, 2015 11:25 PM
Thornburg
Sep 1, 2015 03:39 AM
Thornburg
Aug 27, 2015 08:33 PM
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
