extremely hard start condition
Old Jun 18, 2003 | 09:03 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Just like the topic says. I have to crank the motor over for close to 2 minutes until the motor starts to sputter and eventually start. Nothing has been changed on the car since it started easily.
It happens wether it's cold or warm. No DTC's. Any ideas?
Old Jun 18, 2003 | 09:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Two minutes? Wow.
Does the FP energize when you turn the key on?
Checked the Fuel Pressure?
Try a quick shot of starting fluid...just one second of a blast..then try to start it...if she fires off, it'd indicate fuel/fuel delivery related.
How's it run once it's started?
Old Jun 18, 2003 | 09:16 PM
centaur's Avatar
Car: 1991 GTA
leaky injectors cause hard starting so do bad valve seals, flooding and oil a spark plug does not like...
does it smoke blue on start up? If not check your plugs and see if they are soaked with fuel.
Old Jun 19, 2003 | 07:43 AM
Engine: LB9/383
Fuel pressure is good at 40psi. Valve seals are brand new and there is no blue smoke. Once it's started it runs OK. Plugs aren't fouled up at all.
Old Jun 19, 2003 | 10:18 AM
Cool Runner's Avatar
Car: 86 Trans Am WS6
Just as a test try flooring the gas pedal for a minute then release before trying to start the motor. If this helps it start easier then you have a leaky injector.
Another way to do it would be to take the intake tubing off the throttle body then open the blades and sniff for strong gas fumes.
It might not be the case but at least it's one less possibility eliminated.
Old Jun 19, 2003 | 02:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Is that 40PSI when you turn the key on (no start), or only running?
Check the TPS voltage. Check CTS reading on start up. If you have a scan tool, check the IAC counts as well. Any gunk in the TB? Has been cleaned in last year or so?
Squirt a shot a starting fluid in the TB prior to start, could be fuel related, maybe Cold Start valve has issue.
Old Jun 19, 2003 | 05:21 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Sounds a whole lot like a shot FP relay. When that happens, the ECM can't prime the system before you start it. So you crank and crank until you make enough oil pressure to close the switch and make fuel pressure.
Old Jun 19, 2003 | 09:20 PM
Engine: LB9/383
TPS has been set, I don't have a scan tool. Hopefully a buddy who has one will be coming over soon. Starting fluid doesn't help. The engine sputters when it ignites the fluid and only the fluid. It seems like a fuel delivery problem to me. The fuel pump comes on with the ignition, by-passing the relay. I'm using an '89 .bin file for my ECM so the CSI valve isn't being used. I tried burning a PROM with the CSI enabled and it had the same problem. The TB is spotless. Its a new motor and I cleaned everything before I put it together.
Thanx for the info.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
cstrobel65
Aug 15, 2015 10:19 AM
Exxon Limited
Aug 9, 2015 08:13 PM
