o2 sensor reading
Old Jun 19, 2003 | 08:01 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
o2 sensor reading
I have an 89GTA 355,10.9-1 comp,zz9,24lbs,hypertech in-line pump,big mouth,large tube,52mm,jacobs coil,msd.When I WOT i see on my scanner .74 and then climbs to .78, meanwhile knock sensor is bugging out. Is that programmable in the chip? Do I have another problem? Any suggestions?
Old Jun 19, 2003 | 08:42 PM
centaur's Avatar
Car: 1991 GTA
Sounds like it is running VERY lean! Your lucky you haven't melted a piston or two! I believe those numbers should be in the .900 range!
Nearly 11to1 comp and stock 89 PROM?!!! No wonder the knock sensor is going nuts, you've probably got some major detonation hapenning.
Get custom PROM burned on a dyno, hopefully that will solve your problems.
If your car was a 305, be sure to get a 350 knock sensor as they are different.
Hope your engine is OK.
Old Jun 19, 2003 | 08:46 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
chip is burned from tpis.
Old Jun 19, 2003 | 08:48 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
I thought the knock sensor was the same. Anyway its new from TPIS.
Old Jun 19, 2003 | 08:50 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
numbers on the o2 are from the scanner which is .100 less than actual value.
Old Jun 19, 2003 | 10:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I also get the same WOT 02 readings .780-.830 max
eightsixseven
Dec 16, 2024 01:50 PM
Bstrang6
Sep 8, 2015 04:29 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
