HELP! Engine dies when I give it gas
Old Jun 21, 2003 | 09:33 PM
1lecamaro's Avatar
89 350 TPI
I have replaced my fuel pump and filter after thinking it wasnt getting enough fuel. I can raise the revs if just very very slightly increasing throttle barely any more and it starts to die and cuts out but sometimes if I let off it keeps running. I really need everyones help to get this fixed.
thanks
Let me know if you need more info
Old Jun 21, 2003 | 09:38 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Need to check the fuel pressure. Let us know what it is with engine off/key on until pump shuts off. Let us know what it is cranked then what it does when you press the pedal.
Old Jun 22, 2003 | 12:41 AM
ULTM8Z's Avatar
Did this problem just start "out of the blue"? Or did you work on some part of the car and then it started?
Looking for a clue....
Old Jun 22, 2003 | 08:46 AM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
i had the exact same problems a few years ago. it would run fine if i didnt give it no gas but then if i gave it gas it would die. it turned out to be my ecu got a new one then it ran fine.
Old Jun 22, 2003 | 10:06 PM
1lecamaro's Avatar
I found It!! It was a bad MAF sensor, borrowed a friends and runs like a champ. Thanks for everyone's help
jklein337
Sep 19, 2018 06:23 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
wayshegoes
Aug 17, 2015 12:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
