No start condition, tried the usual suspects...
Old Jun 24, 2003 | 04:36 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Hey guys, I figured I would try in here and see if anyone had any ideas what is going on with my car.
On the way back from the nationals sunday my car is cruising along for about 30 minutes and just up and dies. No warning, just quits. I checked all the usual stuff, fuses, etc. I can hear the pump run when I turn the key on, I have tried so far:
dist module
ESC module
coil
coil wire
ECM
fuses
rewiring ecm power feed line
rotor
memcal
kicking it
Anyone have any ideas? Like I said, I can hear the pump run, the engine rolls over easy, just no startup. Is there a way of seeing wether the injectors pulse when trying to start? i was guessing that it would get +12v across the terminals intermittently, but no good. Also, there is NO spark coming from the coil when trying to start, either.
Help! :hail:
Old Jun 24, 2003 | 11:46 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
Did you buy a napa ignition module, because those are bad right out of the box.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 16, 2015 05:45 PM
