injector size
Old Jul 2, 2003 | 01:05 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
injector size
hey I bought some 24# accel injectors for my 383 I wanted to know if they would be big enough to support the engine it's got a 218/220 cam with 480 lift I think.. pro topline heads... super ram 58mm throttle body. base was portmatched to the superrams runners.
I think it's going to produce 400/500hp?
Old Jul 2, 2003 | 04:19 PM
Gruvin84SS's Avatar
injectors
Nope, they are too small. You can boost the fuel pressure with a AFPR to help compensate but you can probably max out theduty cylce. Look at Mike Davis, he has 30#ers in his 350 ZZ4 Stealth Ram.
Old Jul 2, 2003 | 09:42 PM
level's Avatar
Car: 1987 transam
damn don't wanna run a afpr I orderd them from jegs so i'll send them back but what size should I order?
the listing on jegs said 24 would be good up to 450hp is that rwhp or fwhp?
Old Jul 2, 2003 | 10:40 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
go with the 30lb injectors, better to go a little big than too small IMO. You can always reduce the duty cycle but you can't increase it enough if the injector can't supply the fuel.
Old Jul 3, 2003 | 09:10 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I maxed out a set of 24lbers with my current combo, a 350. I can see a 383 needing even more fuel.
Old Jul 3, 2003 | 04:03 PM
Gruvin84SS's Avatar
30#ers
I have a set of 30# ones for sale if anyone is interested. They have very few miles on them and are too small for the new application. I would like to see about 160.00 shipped. Email me at Gruvin84ss@aol.com if interested.
Old Jul 5, 2003 | 11:28 PM
level's Avatar
Car: 1987 transam
would 32 pound be to big? jegs have them on sale for $199 yes i'm trying to be cheap
Old Jul 25, 2003 | 09:21 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
I'd say the 32lbs is too big. sometimes bigger isn't better. You better stick w/ the 30lbs IHMO
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
