LT1 retro intake-anyone having cooling problems?
Old Jul 2, 2003 | 01:21 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
I am guessing it is my single factory fan for the orig 5.0 but i wanted to see if anyone was having any problems with their eng running hot after the swap. Eng particulars: 350, Hot cam with 1.5 rr, edle uncoated headers, 160 stat, LT1 intake, 9.75/1 comp. Running almost 220 last evening when it about 75 to 80 out and late evening light. I think the cooling system should be able to keep it down around 180 to 200 or at least bring the temp down faster.
Would a factory dual fan be a good cooling upgrade or should I go aftermarket?
Old Jul 2, 2003 | 01:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
check the usual stuff:
1 check your timing
2 check/replace radiator cap
3 make sure your air dam is still in place
4 make sure fans are kicking on when they should
5 check your coolent level both in the tank and in the radiator
Old Jul 2, 2003 | 03:47 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
https://www.thirdgen.org/techbb2/sho...hreadid=187264
Thay are kinda hard to fill with water. i dont think you will have any issues with cooling.
Old Jul 2, 2003 | 05:51 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
1 check your timing
1. I now have timing up to about 18 to 24 at idle, worked great for getting my vette to run cooler, esp on the exhaust. It has run warm sincec I bought it.
2. Will do, might put one of these in:
3. Still there.
4. Got it coming on at 184 degrees, off at 174.
5. I put in almost all dist water and 2 bottles of water wetter, both level check out OK.
Old Jul 2, 2003 | 06:01 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Must have glossed over the cooling section of that post. Must be something not up to snuff with my system. One thing I did not mention is that have one of the K&N tb cone filters which is sucking in hot as$ air which might not be helping the situation.
Where in Ohio are you? Did I buy that 5 speed shifter from you? If so I think you said your are in Dayton. How far are your from the OH/MI border? We are renting Milan drag way on Sept 25th if you are interested. I will be running both my cars that night.
Old Jul 2, 2003 | 07:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
specific to your swap, make sure your replacement thermostat housing is not the highest point in the system... that will cause air bubbles....
Old Jul 2, 2003 | 08:37 PM
ragtop88's Avatar
Car: '88 Camaro ragtop
Engine: 379 destroker
Transmission: m6
Axle/Gears: 10-bolt/3.42
I found it necessary to burp the system after going to the LT1 intake but I do not have any more cooling problems than I did with the Super Ram and I'm using the single TBI cooling fan with my 379.
Old Jul 3, 2003 | 10:57 PM
Car: 1991 Firebird
Engine: 427 LSX
I am from Toledo. I did sell a hurst 5 speed shifter, I can't remember whom I sold it to. Anyhow, I would really enjoy to go to Milan on 9-25. Hopefully, I can get my n2o hooked up by then. I have high expectations with this 406 on the bottle.
midge54
Dec 27, 2019 04:14 PM
fbirdroller
Sep 2, 2015 10:27 PM
TheExaminer
Aug 19, 2015 10:07 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
