engine noise
Old Jul 5, 2003 | 07:20 PM
sonnyb's Avatar
engine noise
my 1991 z28 tpi 350 is making a clicking sound. i replaced the rollers lifers with new lifters and i am getting the same clicking sound from the engine? the oil pump has also been replace. could it be that the heads are bad or some other valve train items. need you asap.
Old Jul 5, 2003 | 07:23 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Have you checked for exhaust leaks?
Old Jul 5, 2003 | 08:04 PM
sonnyb's Avatar
engine noise
yes, i check for exhuast leaks and there is none. when i said clicling noise i should have said, it seems as if the engine is not getting oil to the lifters.
Old Jul 6, 2003 | 06:13 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Are you sure that the valves were adjusted properly after you swapped the lifters?
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
