Need a little help, pleaseeee
Old Jul 16, 2003 | 07:11 PM
afast87's Avatar
i tore apart mt tpi, and the camera chip i used as a picture log died, i have 3 holes on my manifold, what goes in them.
on the front under the coolant outlet, i think temp switc hfor the ecm
same area just left of that one. i think cold start switch
also just above the cold start injector, no clue at all
car is an 87 GTA. L98
T.I.A.
scott
Old Jul 28, 2003 | 12:46 AM
bowtie4ever1986's Avatar
ok the hole above the cold start is for the pvc valve the 2 on the front is the cold start and the cooling fan switch. i hope this helps if you need to email youre number and ill look on my car and tell you. good luck . be carefull taking things apart.
irocz253
Carburetors
19
Aug 3, 2014 07:01 PM
Sam L.
Mar 25, 2014 12:24 PM
irocz253
Carburetors
Nov 26, 2013 09:46 AM
leezickmund
Carburetors
Apr 28, 2013 07:57 PM
thegoochking
Sep 13, 2010 04:55 PM
