will vortec heads work with edelbrocks hi flow intake
Old Jul 20, 2003 | 12:33 PM
stuart's Avatar
Car: 88 gta ....89 formula 350
Engine: 5.7......383
Transmission: heavily reworked 700r4
im building a 383 stroker and would like to use the vortec heads. will the edelbrock hi flow intake work with these heads with no machining? will these heads out flow a fully ported set of L-98 heads? and does anyone know what size combustion chambers are on the L-98 heads?
Old Jul 20, 2003 | 03:57 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
the edelbrock TPI base will not fit Vortec heads. You're going to need the SDPC (Scoggin Dickey) base to fit the vortecs.
Old Jul 20, 2003 | 04:27 PM
stuart's Avatar
i do understand that they wont fit because of the bolt pattern but my local machine shop has a template to drill the extra bolt holes. my concern is with the taller intake runners. will the edelbrock intake have to be machined for the extra clearance?
Old Jul 20, 2003 | 04:50 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
the bolt pattern isnt the same.. and I believe
the intake ports are taller than other head design.
Old Aug 20, 2003 | 02:10 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
the SDPC tpi vortec lower intake is made by Edelbrock. I would the port design is also a little different. I would recommend getting the proper intake
Old Aug 20, 2003 | 04:55 PM
OMINOUS_87's Avatar
Vortec head ports are as tall as a Felpro 1206 gasket, they will not match your intkake, sorry!
Old Aug 20, 2003 | 08:28 PM
IROCZ315's Avatar
Not like it isn't possible to have the intake ported out and have metal added to the ports to make it a 1206 size. I know because I bought one used that had this done.
It still won't flow as good as the intake that is designed to work with the Vortecs.
Old Aug 20, 2003 | 09:08 PM
OMINOUS_87's Avatar
Sure you could play Ring Around the Rosy all day long with your intakes but why bother, just do it right the first time and forget about it!
Old Aug 20, 2003 | 09:25 PM
IROCZ315's Avatar
I am not using Vortec heads so I have nothing to worry about.
Old Aug 21, 2003 | 11:16 PM
stuart's Avatar
well, ive decided on the vortec scbp.........with my ported and polished vortec heads they should do well with my 383..........im hoping anyway.......thanks guys for your replys.........
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
