TPI Sensor locations
Old Jul 30, 2003 | 10:06 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Hi,
I'm swapping a TPI system into a TBI car. Here's what the situation is. I have a 1992 RS that I'm pulling out the 305 TBI engine and I'm putting in it's place a 1968 327 and I'm using a TPI system out of a 1991 GTA to fuel it ( Miniram soon). I have all the parts I need to do the swap. What I need to know is on the older block where do all the sensors go. If anyone has done a TPI swap with an older block can thay give me the locations of where they put all the sensors?
Dustin
Old Jul 30, 2003 | 10:34 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
My motor swap used an 80 block in my 92 and they are pretty similar.
Lets see if I can remember.
Knock sensor= lower right side of block just above oil pan
Secondary fan switch=right side head between 6 and 8
Temp guage sender=left side head between 1 and 3
MAP sensor=attaches to upper plenum
Coolant temp sensor=front of lower intake
Manifold air temp=underside of plenum, can be relocated before
TB
Oil pressure sender=above oil filter in block (diff on older models)
TPS=on throttle body
IAC=on throttle body
VSS=in transmission
Can't think of anymore off hand, hopes this helps
Old Jul 30, 2003 | 10:38 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The knock sensor is the only one that goes into the block. There is normally a threaded hole just above the fuel pump opening on the front of the block. You can get a fuel pump block off plate at Pep Boys or most any other parts house. I hope the TPI you have is a speed density type. Easier to install on late model engines.
Old Jul 31, 2003 | 02:22 PM
ULTM8Z's Avatar
TB
VSS=in transmission
You nailed it!
Those are the same locations I put my sensors on my 1971 block, and then later on my ZZ4.
Old Jul 31, 2003 | 03:47 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
THe only thing I had to do differently for my swap was put the knock sensor on the left side. I am running the Hooker Super Comp headers and there is no room for the knock on the right. However, there is a hole in the block in about the same location on the left and ample clearance to the headers. The wire for it was easily fished out of the loom and rerouted; I didn't even have to lengthen it.
Pro-Tour:
Was your car featured in Chevy High Performance a little while back?
Old Jul 31, 2003 | 05:30 PM
Sweet, thanks guys. That's exactly what I was looking for. Now I'm good to go !!
Old Aug 1, 2003 | 08:20 AM
ULTM8Z's Avatar
Pro-Tour:
Yeah, that was me. May 2001 I believe it was.
Old Aug 1, 2003 | 09:21 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
That's cool!!!
Sweet ride!!!
Old Aug 1, 2003 | 10:55 PM
BORLAZ06's Avatar
the MAT sensor...neone got pics where its located. i need to change mine. my maro manual aint here either.
Old Aug 2, 2003 | 02:57 PM
ULTM8Z's Avatar
It's under the upper plenum toward the rear. You can probably see it if you get on the drivers side and look at the rear of the plenum.
Old Aug 2, 2003 | 05:05 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
If you are going to change it anyways, you should relocate it to in front of the TB. This way it won't get heat soaked from the plenum after you are driving for a while. Just a thought...
Old Aug 2, 2003 | 11:09 PM
BORLAZ06's Avatar
sounds like a good idea. thanks guys.
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
