Plenum Porting Question
When porting the TPI plenum, is there any reason not to siamese the throttle body openings together? If I went ahead and made one large oval opening like a monoblade TB requires would it hurt performance any with a stock or 52mm TB?
I dont think so, but i just didnt fock with it and just smoothed out the opening and matched it with the gasket. a Monoblade would be cool, but would be over kill unless you have a 400hp mill. Just open up the openings... dont play around with the center... just my .02
Car: 89 IrocZ
Engine: L98-ish
I bought a plenum from "Mike89GTA", IIRC, and he had done what you did...said he didn't have any issues with it...he upgraded to a SuperRam..reason he had it for sale.
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
I think you time would be better spent on other things. I just ported mine and didn't see a need for it.
Conrad
Conrad
just some info;
the larger aftermarket twin 56mm-58mm throttle bores flow more air than any 4 cylinders can draw during the same time period, theres absolutely no reason to port the twin 56mm-58mm or larger throttle bores into a large oval unless your supercharging or turbocharging the engine and even then twin 56mm-58mm throttle bores are able to supply the engines needs, those twin throttle bores flow over 900cfm-1000cfm, far more than any small block chevy can use. thats 8.24 sq inches of throttle bore, nascar restrictor plates have less than 4 sq inches of flow area yet those engines make well over 650hp
the stock twin 48mm throttle bores do pose a restriction but unless your trying to make over 400hp even those throttle bore sizes are not a big restriction on hp as they flow in the 650cfm range
I'm not talking about porting the throttle body. I mean the plenum in the area behind the TB. I know I'll never have need for anything more than a 52mm and probably not more than my stock 48mm one.
