Fuel Pump Recomendations?
Old Aug 25, 2003 | 03:15 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Hey Guys,
My factory fuel pump bit the dust. My car has an LS1 engine so I need more pressure than stock.
Can anyone recomend a good high performance replacement unit that does not require modification. In other words I would like one that will fit right into the old in tank bracket setup.
Also, any hints on replacement would be great.
BILL
Old Aug 25, 2003 | 08:40 PM
BOTTLEDZ28's Avatar
Transmission: A4
Ive got a Holley in tank unit and it works great. I think its the 255lph one. I paid a little over $100 for it. That should be plenty for the LS1 engine with mods done. Have fun changing it. make sure you have a case of beer handy and few helping hands. DO NOT CUT THE CAR OPEN. take the rear out.
Old Aug 25, 2003 | 10:45 PM
Kandied91z's Avatar
check out walbro pumps their top model will work fine. do a search on the internet and you'll find all you need to know.
Old Aug 25, 2003 | 10:55 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have a Walbro. I like it. Others run them that I know and like their Walbros as well.
As noted above, google search, Walbro fuel pump, pick a distributor..... Done.
Old Aug 25, 2003 | 11:28 PM
wm_sorg's Avatar
Thanks guys. I ended up with a walbro unit (HP 255?) This looks like it will be a pain in the A$$. Of course I filled the tank 5 minutes before this happened.
The rear will be droped. No way am I going to cut the body.
Old Aug 26, 2003 | 02:06 PM
Kandied91z's Avatar
empty the tank, it will make it alot easier....i'm sure you already know that though.
good luck.
Old Aug 26, 2003 | 04:59 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
go w/ the racetronix kit that is designed for higher pressure applications... i know the LS1 cars run more like 55-60 psi...
here is a link to the racetronix page
http://www.racetronix.com/product/RX..._Pump_Kit.html
the gss340m is the pump for the higher pressure use... i know several guys who have run those...
Old Aug 26, 2003 | 05:46 PM
Kandied91z's Avatar
yep, i have the 340 setup....it seems to work quite well. works better then my old gm upgraded intank with a ati booster pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
