Anyway to increase Throttle return resistance?
Old Sep 7, 2003 | 12:33 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Anyway to increase Throttle return resistance on a TPI?
the little spring on my Throttle Body isnt as tight as i wanted it to be.....any way to increase it? i noticed its sorta riveted in...
Edit: This is for a 89 305 TPI
Old Sep 7, 2003 | 01:47 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You can add in a secondary spring from a Q-jet or other carb and hook it to the bracket on the plenum.
Old Sep 7, 2003 | 02:57 AM
HamSpiced's Avatar
braket?
Old Sep 7, 2003 | 11:57 PM
bigals87z28's Avatar
Car: Check The Sig
why again? I didnt know there was a carb-like spring? just the one mounted to the blade axle? Im assuming he ment to make a braket and put a carb spring from there to the throttle.
Old Sep 8, 2003 | 09:46 PM
HamSpiced's Avatar
well the current spring on my throttle body is sorta loose.. and i can feel a gap of pedal, rather then increase the idle, id rather increase the throttle resistance, i was hoping there was a way to do it without fabbing a bracket and without buying a new TB.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
