305 tpi sudden loss of tq
Old Sep 7, 2003 | 02:46 PM
NEOMASTERZ28's Avatar
Car: 85 z28
what will make a sudden loss of tq on a tpi, i plan to give it a full tune up and put an o2 sensor. anything to explain why a sudden loss of tq????????
Old Sep 8, 2003 | 09:40 PM
Car: 85 z28
anyone ?
Old Sep 8, 2003 | 10:29 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
try resetting the ecm. see if the power comes back.
SD or MAF?
Old Sep 11, 2003 | 10:08 AM
Car: 85 z28
maf
Old Sep 11, 2003 | 02:13 PM
ULTM8Z's Avatar
My guess would be on the fuel side.
Fuel pressure?
Fuel filter?
Check these and let me know.
Old Sep 11, 2003 | 02:24 PM
Car: 1988 IROC-Z
o2 sensor would be a cheap start. once that is done replace the fuel filter as stated. if at all possible check the fuel pressure and report back with results. after replacing these things reset the ecm to clear it out and give it a fresh start. tune up wouldn't hurt if one hasn't been performed in a while.
Old Sep 12, 2003 | 12:42 AM
bigals87z28's Avatar
Car: Check The Sig
vaccum leak, blown rings, rockers losen up, crappy gas, timing's off,... could be serveral things.
Old Sep 12, 2003 | 01:12 AM
sllt1776's Avatar
Car: 89 Iroc-Z
you didn't mention if you were getting any codes. your cat could be clogged. when mine did...it was on a trip, just all of a sudden it started to bog and in a minute the top speed was maybe 20 mph. how old is your cat?
Old Sep 14, 2003 | 01:28 AM
Car: 85 z28
ok well , i did a complete tune up. plugs,cap,rotor, all brass, new fuel filter,oil change o2 sensor. and it still bogs after wot about 3500 the tq will die and the car like jumps back, like backing off.
no codes just the egr one on the hwy.
timing is at 6 and there was a lil vac leak but still the car is still the same
sllt: the cat is the factory 1 chould be bad but i think i should plan to cut it off
Old Sep 14, 2003 | 09:40 PM
sllt1776's Avatar
Car: 89 Iroc-Z
well if there are no smog checks then do what ever you feel comfortable with. i would fix the vacuum leak. it may be causing the egr failure and maybe some other problem. i think just buy a hose need to replace all the vacuum lines at once, it's not too much and you can then rule that part out
Old Sep 15, 2003 | 01:44 PM
ULTM8Z's Avatar
Check your Throttle Position Sensor. It should be set at approx .6 V at idle. With a digital voltmeter on the blue (+) and black (-) wires, slowly open the throttle and observe the meter. It should smoothly go from the ~.6V to ~5V. If there are any spikes or sudden drop-offs along the way, you likely have a bad TPS.
The TPS triggers the "acclerator pump" for EFI. It tells the computer that you have suddenly increased the throttle and therefore need some more fuel. If the TPS loses the signal, it would be like taking the acclerator pump off a carb- the car would bog.
Old Sep 15, 2003 | 06:25 PM
Car: 85 z28
how many volts should it have at wot ?
Old Sep 16, 2003 | 08:47 AM
ULTM8Z's Avatar
I believe it's 5V at WOT. The ECM sends out a 5V reference voltage for the TPS to work with. The TPS, being a potentiometer, simply regulates the voltage sent back to the ECM depending on what position the throttle shaft is in.
Old Sep 16, 2003 | 06:09 PM
Car: 85 z28
At wot mine does not read 5v it reads 4.2 or 4.3 i rember reading it somewhere that it supposed to be 5 but im not sure so, its set at .54 and keeps the setting but not 5v at wot
plus there is a tq increace when the ac is on it even makes the tire chirp 2nd ? but not that much when its off
Old Sep 17, 2003 | 08:53 AM
ULTM8Z's Avatar
When was the last time the injectors were professionally cleaned or replaced?
Old Sep 17, 2003 | 04:03 PM
Car: 85 z28
never stock 85 injectors, never had a professinal injection clean service i know some are a piece of crap but what shop do you recommed?
so what about read 4.3 volts a wot on the tps
Old Sep 17, 2003 | 05:14 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
anything close to 4.5 to 5.0 is fine.
Old Sep 17, 2003 | 05:40 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Hook the car up to the laptop and take it for a ride and then watch your knock retard.
Before i started paying with the chip I had the same symptoms and my car was tuned up well. I hooked it up to the laptop and logged some data and i noticed that i was getting 10-14 d reterd at around 3500 RPM and it felt like the car wasn't pulling anymore but the RPM went up.
The spark advance on the original chip was way too much for my car. When i lowered the spark advance and took the car for a ride the knock retard was almost non existant and my car felt like a v8 should feel all the way up to 4500 RPM.
Just a thought.
D
Old Sep 21, 2003 | 02:54 PM
Car: 85 z28
i just got the fp to 52psi and still no difference still boggs at wot or somtime in second at wot
on tpi when u go wot your giving it alot of air then air hits fuel so chould it be injectors?
or tranny casue some1 did mention that
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
