G1 trickflows and roller rockers?
Old Sep 26, 2003 | 04:15 AM
STIFFLER's Avatar
What kind of roller rockers should I get for a set of G1 trickflow heads.. can I get away with roller tip? or do I need full roller? and what brand to buy... of course I called trickflow and they said "buy there roller rockers and do not use stampers of any sort.." can you guys help me out
Old Sep 27, 2003 | 08:20 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
Do you have centerbolt valve covers or what? If so I think the only rockers that will fit are the crane gold rockers. I've been through this painful process and lost a lot of money. Let me know what you have as far as valve covers go.
Old Sep 27, 2003 | 08:25 PM
87GTA Runner's Avatar
Car: 87 GTA
Trick Flow also makes narrow width rollers for centerbolt heads. That is what I got when I got my 23* heads from them.
Old Sep 28, 2003 | 03:44 PM
STIFFLER's Avatar
I have centre-bolt heads
Old Sep 30, 2003 | 09:21 PM
ericoo1's Avatar
Car: 89 silverado,02 s10 blazer
GMPP makes a set of 1.6's that will fit
Old Oct 2, 2003 | 05:39 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Caution - difference between Crane Gold and GMHPP rr's
Although Crane does make the rr's for GM that are sold for use with the LT4 hot cam kits, they ARE different from the Crane Golds in one aspect. The slots are shorter, and a combination TF G1 head and cam in the .525 range can cause contact between the end of the slot and the polylock body. Also, the polylock design has a short hex on the top for clearance with centerbolt valve covers, and this can contact the top surface of the rocker body at full open and full close of the valve.
Old Oct 2, 2003 | 07:18 PM
Desert86Roc's Avatar
I have used both Crane Gold 1.5s and currently Comp Pro-Magnum 1.6s. I used tall valve covers to prevent the clearance issues.
Old Oct 3, 2003 | 03:59 AM
STIFFLER's Avatar
Well I just have the stock valves that came from trickflow... so crane roller rockers will work for me?
Old Oct 4, 2003 | 10:05 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
I am running 1.5 Crane gold rollers with my G1 heads and hot cam using the chrome GM valves covers so I would expect them to work with the stock valve covers.
Old Oct 5, 2003 | 08:19 PM
Car: 87 GTA
Hey Fevre. How do you like the Hot Cam? I plan to get this to use with my 23 degree heads and 1.6 RRs. Did you update the ECM or are you running it as is? Thanks.
Old Oct 6, 2003 | 03:22 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
It is a great street cam with lots of mid range torq. I have the accel FI but I would expect you would need to make a prom adj if using a GM system in order to get max results. I also have the retro fit LT1 intake.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
