Anyone seen these new MAF sensors on ebay???
Old Oct 5, 2003 | 12:40 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2435461185
Just thought I would post this up. Any validity to this product?
WILL
Old Oct 5, 2003 | 01:10 AM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I searched around a bit, and found their website.
http://www.micro-tech-auto.com/maf.htm
I'm interested - has anyone tried one?
Old Oct 5, 2003 | 01:30 AM
norcalz28's Avatar
That is my concern, as they have a 0 ebay history, and it seems no one has tried them yet. I was interested as well
Will
Old Oct 5, 2003 | 02:00 AM
Morley's Avatar
Looks like the Wells unit without the screen, and for more money.
Old Oct 5, 2003 | 02:28 AM
biff85ta's Avatar
Car: 04 Vette
Not to mention he lists it as working for an 85 and there is no resemblance to the one on my 85 what so ever.
Old Oct 5, 2003 | 10:30 AM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Yeah, but if they recieved a patent for their design, then it must be different, right? If they were pulling a TPIS and just reselling someone elses part, they wouldn't have been able to patent it.
Old Oct 5, 2003 | 11:05 AM
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
I actually have the first one made. I found that the non-adjustable MAF from Micro-Tech reported a higher voltage at every airflow than my stock MAF. With the adjustable MAF, I could turn this voltage down so the ecm was getting the correct reading and using the appropriate MAF table value (this eliminated the rich condition caused by a false high MAF reading).
Two changes I had to make in the prom: increase the MAF high error value from 45 to 65gm/sec and increase the MAF vs rpm table values by 20%. I'm using the ARAP, $6E mask.
I am very happy with this MAF but I had to make the above changes to use it to it's fullest potential.
Old Oct 5, 2003 | 01:57 PM
Morley's Avatar
All of the "hot wire" MAF's looked alike, the 85 had a little bit different circuitry, it used a pulsed voltage instead of a steady DCV signal.
Old Oct 5, 2003 | 10:49 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
unless u burn a new chip for the ecu a larger maff will not have very much effect beacouse the normal ecu will be maxed out and not know how much air is flowing in
Old Oct 6, 2003 | 03:06 AM
rezinn's Avatar
You should just delete this post.
Old Oct 6, 2003 | 08:34 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
$300? It looks like the same setup as the Wells, and if you want adjustability that bad you can wire a potentiometer to the wells. Personally I see no advantage to having the adjustability if they could have gotten it to produce the proper voltages in the first place.
Old Oct 6, 2003 | 01:11 PM
biff85ta's Avatar
Car: 04 Vette
Ever looked inside the 85 maf???
Old Oct 6, 2003 | 02:08 PM
Guest
Guest
Posts: n/a
I've owned an 85 and I have an 86 and a 89, there isnt any visible difference in any of them.
And yes, that looks just like a Wells with no screen.
Old Oct 6, 2003 | 02:10 PM
Jim85IROC's Avatar
I took a picture of the 85 MAF right next to the newer style and right next to the Wells. The 85 looks the same inside, except that the wire is a c-hair thicker.
The screens on the 85 are very different however, and can be used to identify it as such.
Old Oct 7, 2003 | 12:14 AM
Morley's Avatar
Yep, every time I remove mine.
BumpaD82
Feb 26, 2016 02:57 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
earlpote
Sep 12, 2015 11:55 AM
e3pres
Sep 9, 2015 01:51 PM
