The difinitive IAC resetting post
Old Oct 8, 2003 | 03:31 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Ok guys, I've already searched this site and I also have both chilton and hayne's camaro manuals. I am still somewhat confused though.
At what point in this procedure do I remove the A-B diagnostic port paper clip? I've read that starting the engine with those ports gapped will damage the computer, but the manuals never say when to take it out during the whole process of resetting the IAC which requires starting the engine more than once.
I would just adjust my idle-speed stop pin at the plenum because it is way too low, causing me to sometimes double-foot it at stoplights, but I've also read that doing this will damage the IAC motor in the long run.
Old Oct 8, 2003 | 04:56 PM
llvll4l2c91350's Avatar
unplug IAC
remove clip from ALDL connector
start engine
Old Oct 8, 2003 | 08:33 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Read 'turning the screw', and for that matter the rest of this article also.
http://us.f1f.yahoofs.com/bc/3f73a82...zwLh_AiHitTNyy
Old Oct 9, 2003 | 02:58 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
:me couldn't get that article to load...
Old Oct 9, 2003 | 06:53 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Short A to B
Turn key On
Wait 30 secs
Unplug IAC
Key off
Unshort A to B
Start engine and set min idle, TPS what ever.
Take car for test drive and exceed 35 MPH a few times, this forces an IAC reset, in the ecm code wise.
Stop and Recheck idle.
Things should be OK.
If the adjustment was fubar'd or there is some loose gunk it might take a redo.
Personally I don't like reling on the IAC to maintain an idle, so I typically set the min idle speed so that there is less then a IAC count of less then 10 at idle.
Old Oct 20, 2003 | 12:16 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Ok I reset my IAC and am very satisfied with the new idle. At a stoplight it is at a strong 600 rpm. I had to fully extend the throttle stop pin though, while resetting the minimum idle speed. When I first start it up it revs up to 2000 and then comes back down. I think that is kind of high. And in park it will sometimes hang at 1500. Are these indications of a faulty IAC motor? It's a couple months new from Autozone, so carbon buildup isn't an issue.
Old Oct 20, 2003 | 03:21 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Originally posted by Grumpy
Short A to B
Turn key On
Wait 30 secs
Unplug IAC
Key off
Unshort A to B
At what point are you supposed to plug back in the IAC?
Old Oct 20, 2003 | 04:13 PM
88TAJeff's Avatar
Car: 88 T/A
James/Bob,
you can plug the IAC in after you shut the car off, or even when it's running. It won't do anything though,until you shut the car off and restart it.
BTW, neat name, the same as my 2 brothers.
Old Oct 20, 2003 | 05:38 PM
jamesbob02's Avatar
Car: 92 Z28
It's strange, my name is neither James nor Bob - when I started online ages ago, my friends called me Jimbob, but it was taken, so I've been JamesBob ever since. Just some thirdgen technical knowledge everyone should know, right there lol.
Old Oct 22, 2003 | 01:24 PM
mr. listo's Avatar
Car: 1989 iroc-z
Engine: 350-5.7ltr
Transmission: 700r4 automatic
when I try to reset the iac on my 89 iroc 350 5.7.
at the point after I disconnect the iac and try to start my car it wont stay on, unless i give it gas. what kind of problem do you think I have. thanks camaro bros.
Old Oct 24, 2003 | 01:44 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
This is probably stupid, but are you sure you unshorted a and B by taking the clip out? If you leave it in and try to start it, thats what will happen.
Chuck84TA
Jul 15, 2016 09:05 PM
bamaboy0323
Sep 3, 2015 06:07 AM
greenyone
Sep 2, 2015 03:39 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
