throttle body ???
Old Oct 12, 2003 | 03:02 PM
kustom71's Avatar
throttle body ???
I need to know if there is supposed to be any play in the throttle body shaft.The end where the cables connect.Mine seems to have some play and i cant get my car to idle smoothly at all or idle under 800 rpms.If there is not supposed to be any is there a way i can fix it nyself or do i need another.I also think i have some leaking injectors i will check them 2morrow.Thanx for any help!!!
Old Oct 13, 2003 | 10:11 AM
Formula383's Avatar
Car: 88 Firebird Formula
I have the same problem w/ my Holley TB. My buddy said that I need to get a new one.
Old Oct 13, 2003 | 11:12 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
There should be very little to no play at all from the TB shaft. Most likely worn shaft bushings/bearings are to blame. Common problem. Ebay machinists usually replace them with sealed needle bearings when they perform the overbores on their cores to help eliminate this problem.
I have this problem too and emailed one of the guys about installing the needle bearings without overboring my TB just as a rebuild proceedure. IIRC, he said it would be like $40-$50 plus shipping to do it. I must have deleted the email though, or I would have given you his email address. Just search on ebay and email a few of them and they'll be glad to help you out...
Old Oct 13, 2003 | 12:42 PM
Formula383's Avatar
Is IIRC one of the guys who do this??
Old Oct 13, 2003 | 03:15 PM
bnoon's Avatar
IIRC is internet speak for If I Recollect Correctly. Just search for "TPI Throttlebody" and you should find a couple of the machinists that do these mods. Look through their listing to make sure it's one of them that replaces the bearings with the new needle bearings instead of reusing the stock ones.
Old Oct 13, 2003 | 03:28 PM
Formula383's Avatar
Thanks for the info
Old Oct 13, 2003 | 04:12 PM
kustom71's Avatar
thanks i might be buying one but ill check into it.
Thanx
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
