stumbling problems
Old Oct 20, 2003 | 08:26 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
stumbling problems
Just picked up my car from moms house where it was stored since april. went back occasionally during that period and started it and it ran fine UNTIL -- this time when I went to start it, was very rough until it got to op temp. and when I drove it back on the road, anything more than a few millimeters of throttle and it would stumble badly. luckily that few mm was good to about 75 mph which got me from buffalo to hartford ok.
I replaced the TPS and checked the timing which seemed ok. I also ran 2 tankfulls of 94 through it just incase the gas went bad. I got codes 33 and 34 on the trip back which forced limp home mode but both came when I was coasting into the gas station or a toll booth (very lucky). I think this may have something to do with the new TPS sensor only being held on the throttle body by one screw (other one stripped backing it out).
I was thinking that the injectors might be going bad or baddly clogged (origionals). BTW I can floor it and she runs great. and when I forced the ecm into field service mode it indicated a VERY lean condition when the stumbles (and just about any acceleration) occured. the ses that usually blinks on off once a second wouldent even light at all when I was accelerating but would show stoichiometric at idle or when cruising.
fuel pump is brand new walbro 255
havent changed fuel filter -- will do.
havent changed MAF but I couldent find a place that sells the old wells su145's anymore. autozone doesnt carry ???
all help appriciated.
Old Oct 20, 2003 | 11:22 AM
KYL98's Avatar
Car: 1991 Z28
Codes 33 and 34 refer to Vacuum.....and you mentioned being "lean" also. I would check/replace ALL vacuum hoses, check the runner bolts/gaskets. Id say you have a cracked vacuum line somewhere....or maybe more than one. My car did that after sitting for a while.....HTH....
Old Oct 20, 2003 | 12:05 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yeah -- that makes sense -- will do.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
