Stealth Ram with Stock L98 Cam
Old Oct 21, 2003 | 08:03 AM
lvega's Avatar
Combo:Vortech Heads,mild port,L98 Short Block,3.73 gears,4.3 Stall,Edelbrock TPI Intake System,Stock L98 Cam W/1.6 rockers,will i see much improvement going to a Holley Stealthram
Old Oct 21, 2003 | 08:44 AM
vwdave's Avatar
I dont THINK the stealth ram will bolt up to Vortec heads.
Old Oct 21, 2003 | 11:56 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
It doesnt, as far as I know. You could probably tap yours to fit it, though, if you were set on it. You may also be able to drill holes in the HSR base to fit the Vortec pattern, but I really don't know.
Old Oct 21, 2003 | 12:43 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I asked holley, they said certain years of vortecs will work. There are two generations of vortecs, when they first came out, and the newer version. I'm sorry I cant quote which years work and dont. But it is possible.
Old Oct 21, 2003 | 05:57 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
if it's the newer 8 intake bolt vortec heads, no. even if you drilled the intake to fit the patern, the ports will not match. the newer vortec heads ports are raised.
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
