What can I do with this to make it more " matched"
Old Oct 25, 2003 | 11:22 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I got the Edlebrock base and runners( both mildy ported ) ..... with tthe ZZ4 cam running 10:1 C/R stock injectors and TB . Stock heads with some bowl work and a 3 angle valve job screw in studs ...roller 1.52 rockers.
I am trying to maximize this setup ........ I am assumeing the heads would be the greatest restriction ....... Is there a set of heads out there that would compliment this setup better .......I am reading that bigger is not always better ......
I "might" have a line on a set of Edlebrock RPM heads ......would this be a gross mismatch for this cam and intake?
Old Oct 25, 2003 | 03:09 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
They will work with your setup fine but find out what CR u will have with them heads vs your stock ones. U dont want to be too high depending what his cc is.
Basicaly the true ?? should be how much $$ willing to spend? As theres tons of heads out there that will work. hard to make a suggestion with out knowing your budget. Ex. Vortec to AFR's
Old Oct 25, 2003 | 03:18 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I want to keep the 10:1 compression ratio ...... I can't afford the " correct" heads ..... just trying to come as close as I can to
optimiseing the setup
Old Oct 25, 2003 | 07:32 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Do you have headers on your car. One of the biggest improvements will be to free up the exhaust system if you have not done so already. This will maximize everything else you do ahead of it. Parley
Old Oct 25, 2003 | 09:54 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Yes I am going to get headers .....I wanted 1 3/4 .......so I could use them on a different motor if need be ( I would probably go bigger ) . a 3" exaust will be comeing with it
Old Oct 25, 2003 | 10:30 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
The Performer RPM heads will work fine with that setup if you're getting a deal on them. They'll have either 64cc or 70cc combustion chambers. The 64cc version would be better.
Old Oct 26, 2003 | 11:45 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Thanx man ..... there is a set of 180 Pro Lightening heads I see aswell ..... but they are Iron so......
yes I would like to keep the 10:1 C/R so I am hopeing them heads are the 64cc
thanx
D's89IROCZ's Avatar
Car: 1989 IROC-Z
quintuple post ...sorry Dam dial up ...I thought my computer froze
please selete these wastes of time Mr. Moderator
D's89IROCZ's Avatar
Car: 1989 IROC-Z
quadruple post .....sorry I can't delete these
D's89IROCZ's Avatar
Car: 1989 IROC-Z
tripple post sorry
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Double post sorry
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
