Air foil-really work?
Old Nov 5, 2003 | 07:46 PM
laf723's Avatar
Car: 1989 IROC
Engine: 5.7
Is an air foil worth $50, or would the money be better saved and spent on something else?
Old Nov 5, 2003 | 08:25 PM
bigals87z28's Avatar
Car: Check The Sig
not really worth it. Spend the 50 and get an adjustable fuel pressure regulator.
Old Nov 5, 2003 | 09:54 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Don't buy a TPiS airfoil - they're the most expensive. You can get a new one for less from a different company, and you can get a used one off ebay (many of them). Yes an airfoil will yield a stock L98 or LB9 about 1 hp throughout the powerband. It will yield more the more mods you have.
Old Nov 5, 2003 | 10:35 PM
MdFormula350's Avatar
nice and easy mod for me, i like it.
Old Nov 5, 2003 | 11:07 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I was watching horsepower tv on TNN and they were talking about bolt on mods and had a chassis dyno on hand. Not to say they dont work but they tried one before and after a dyno and it yielded 0 hp at every rpm range.
Old Nov 5, 2003 | 11:38 PM
Car: Check The Sig
if you could find a cheaper one, get it. If not, get something ele that will benifit you more.
Old Nov 6, 2003 | 12:21 AM
rockind78's Avatar
I swear this link should be part of one of those stickys. Hope this helps.
https://www.thirdgen.org/techbb2/sho...hreadid=208593
Old Nov 6, 2003 | 12:30 AM
Car: Check The Sig
Thats a good review, but you have to understand that LT1's and TPI are 2 very different types of EFI intake set ups. Im sure it holds up true, but honestly the air foil for 50 bucks... not worth it.
Old Nov 6, 2003 | 08:34 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I bought the TPIS Air Foil... promised 11hp. Although I don't have a dyno, I could tell NO DIFFERENCE between before and after installation.
Maybe if you did a list of mods to your motor, this would help?
But on a stock TPI, it turned out to be a disappointment and a waste of money.
Hope this helps.
Old Nov 6, 2003 | 07:10 PM
laf723's Avatar
Car: 1989 IROC
Engine: 5.7
Thanks for input. My motor is stock and I was looking small things to begin improving on it till more money is available.
Old Nov 6, 2003 | 07:53 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
well for starters if you have tpi, pick up a set of KN filters, gut the airbox underneath the filters, and open up your plenum a little bit just to start things off. Then next work on the exhaust since they're so crappy on our cars.
Old Nov 10, 2003 | 01:40 PM
Black363IROCZ's Avatar
Car: '88 IROCZ
Engine: 363 Vortec w/Miniram
Transmission: built 700r4
anything that can increase airflow to a motor will gain HP, now is an airfoil worth that price? no, but for $15 off ebay it is, and you can make your won out of epoxy.
Old Nov 10, 2003 | 03:44 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
I'm sure the stock TB can already outflow the runners so it's a moot point.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
kyle5647
Aug 15, 2015 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
