Can I use the plenum from a 87 on my 89???
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I have the opportunity to pick up a used tpi setup pretty cheap for the purpose of polishing it in my spare time, so as not to have any down time on my iroc. The question is, since the 87 was still equiped with that 9th injector, can I still use it with my 89 setup. It seems like the runners on my 89 would cover that extra hole. Is this true? Thanks guys
Will
Will
Yeah, as far as I know the plenums are identical. The 9th injector goes through the bottom flange of the driver's side runner, and straight into the intake manifold anyways. So hopefully no problems for you
Matt
Matt
Wrong, there is more differences than the injector hole.
Plenums and runners are different. The 1987 Iac passage goes thru the plenum and down the runner. the 1989 and up there is a slot in the TB that feeds the air into the engine. You can tell the earlier plenum has a triangle hole in between the throttle bores. the 89-92 has no hole.
Yes.
I had no problems running an 87 plenum on my 89 car. Then I also installed some LTR from the same 87 car on my 89 car. All I did to thr runners was quick steel the hole for the 9th injector.
You would have problems running an 89 plenum on an 87 car I believe. Not the other way, though. At least no problems on my car.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The IAC differences can cause problems when running a newer plenum with an older throttle body, but an older plenum will work fine with a newer throttle body.
If you do have a new plenum and old TB, just drill a 1/2" or 5/8" hole in the proper spot and you're good to go.
Any difference in the lower manifold? I will be keeping my tb, which is off the 89. the only thing I see different is the hole on the plenm/lower intake, which is covered anyway by my runners. Do all TPI lower intakes have the provisions for the 9th injector passage? Or was it not present on the 89+ models
Will
Will
the 9th injector hole has nothing to do with the IAC passage.
http://www.turbotime.us/gallery/bigtime01
That just means the throttlebody matches up with the plenum hole. you still need to have the correct runner and manifold to complete the passage
I would keep the throttle body, get a late plenum, drill the hole.
88SS6SPEED
Nov 11, 2015 07:05 AM
