engine combos
Car: 1988 iroc-z all stock for now
Engine: LB9 305
Transmission: 700R4 3.42 posi rear
engine combos
i am getting a L98 on sunday and was wondering which combos to go with, i have a comp cam 266hr-14 bump stick and am considering aluminum heads but i dont know which heads and intake to go with, im planning on replacing the 305 in my 88 iroc with the 350 and also wanted a possible ball park figure on power, im runnin the 700 tranny and 3.42 posi rear
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
it really depends on your budget,you can do tfs 23*alum heads 190cfm,afr 195s,dart pro 1, give a dollar amount you will spend and you will see combos...
Engine: LB9 305
well for right now im just trying to get some ideas on how to work the L98
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Your budget and intentions will help these guys help you. You can spend some serious dough depending on what you want to do. I'm in the planning stages of stroking my L-98. I have AFR 190's coming ($1200) Just installed Hooker 2055's ($500+) Ported stock runners/plenum (free) with all the mods below(lots of money). If you ask my wife she'd say I'm already done, so dont ask her!! Good luck!
IMissMy86TA
Aug 31, 2015 08:40 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
