Car won't start unless...
Old Nov 27, 2003 | 03:25 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
... I disconnect my EST bypass harness. When connected the car just turns over and over. I just put in a brand new coil and ignition module. (coil has yellow and red wire). What is causing this problem? What is the difference between the yellow and the white wired coils? The engine/distributor is out of an '85 IROC but the computer is out of a '92 Z28.
Old Nov 27, 2003 | 04:48 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
According to the GM Shop Manual for the 86 Vette, if the pick-up coil has a yellow wire, then the ignition coil must have a yellow wire too.
If the pickup coil has a clear or black wire then you can use the ignition coil with a red wire.
Now, this applies to the 86 Vette TPI, and not your specific combination, but GM seems to think matching the wire colors correctly is important.
Jake
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
