BBK Throttle Body on Stealth Ram...HELP!!
Old Nov 29, 2003 | 04:53 PM
irocz43's Avatar
I'm installing a BBK 58MM throttle body and stealth ram on my car and have fitting problems with the cable linkage hitting the front of the fuel rail where the fitting goes in. I read on past posts that others have had these problems. If anyone could tell me the good way to fix this problem and also pics of this would be great too..........THANKS!!!
Old Nov 29, 2003 | 04:56 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Look here for answers...there are a number of solutions
https://www.thirdgen.org/techbb2/sho...hlight=fitting
Cheapest and easiest is a narrower 90 deg fitting from napa.
Old Nov 29, 2003 | 04:57 PM
JMatlock88's Avatar
Car: 1991 Formula
double post
Old Nov 29, 2003 | 04:59 PM
JMatlock88's Avatar
Car: 1991 Formula
I chose to swap to an early TB (see picture)
Old Nov 29, 2003 | 05:08 PM
irocz43's Avatar
So, if i just take this throttle body back i can order up a 1985-1988 throttle body and it will bolt up and work just fine huh? But i would just have to replace the throttle cable with an older style. If i chose to grind on it how much has to come off? do you just grind off the round part where the cable runs at??
Old Nov 29, 2003 | 05:14 PM
JMatlock88's Avatar
Car: 1991 Formula
Just grind it until it clears and no more. (Personally, I dont like that option because it decreases the factory of safety designed into the fitting) Yes, the older TB bolts right on as long as you get an old throttle cable.
Old Nov 29, 2003 | 11:22 PM
biggtime's Avatar
Just buy the holley one. i have a stealth ram with a 89-92 58mm throttl body. Just bolts on like it should.
Old Nov 30, 2003 | 02:21 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I have a BBK 58mm TB on my HSR. I had to grind off just a slight amount of meat from the cable guide. I just used a bench grinder and trimmed a bit, test fit, trim a bit, test fit. Didn't have to remove much and it didn't take very long...
Old Nov 30, 2003 | 02:38 PM
JMatlock88's Avatar
Car: 1991 Formula
Same here...that's a BBK 58mm in the picture
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
