siamesing the runners how exactly?
Old Dec 3, 2003 | 12:01 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
i did as search and cant find the correct answer i want, i want to know what do i use to siamese the runners together i read the tech board article but there is no refrence to how to put them together besides the pictures, i want to know if they have to be welded or can they be done another way
Old Dec 3, 2003 | 02:52 PM
rezinn's Avatar
In siamesing aftermarket runners, you just cut away the material inside and smooth it down. Siamesing stock runners would be more difficult. You'd not only have to cut everything you want to get rid of out between the runners, but also weld a plate over them to reseal. Using anything other than welding would probably fall apart eventually(thinking jbweld or some epoxy?).
Old Dec 3, 2003 | 03:29 PM
yeah i was thinking some high temp epoxy with, this sounds weird, but the metallic tape you use on temporary exhaust repairs, because i was told welding aluminum is really hard due to the fact it can warp due to the heat and i dont know anyone with that expertise in welding, but if it wont mess up the runners my buddy welds
Old Dec 3, 2003 | 03:44 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Tig welding is about the only choice you have.
Old Dec 3, 2003 | 05:43 PM
Guest
Guest
Posts: n/a
IMO the vibration is going to kill the epoxy idea before it gets off the ground. The stock runners are so flimsy I bet they sing like mad at operating RPM's.
Old Dec 3, 2003 | 06:24 PM
wheres the best placed to get aftermarket runners? or the best ones to get on a moderate budget and which are the best ones period? cause i would like to get quality but if i have to save up money i will my iroc is garaged anyway and wont be out until spring/summer
Old Dec 3, 2003 | 06:57 PM
raefon's Avatar
Car: 1991 RS (being reworked), 2002 Ram-Air Trans Am
Engine: Will change soon
Transmission: Will change soon
I have been doing a lot of research in this area, and the best bang for the buck seems to be the SLP runners.
http://www.slponline.com/view_produc...RTNUMBER=20004
Good luck
Old Dec 3, 2003 | 07:19 PM
5SIZ's Avatar
Car: 1987 IROC-Z
If you really want to go the Siamesed route, then go with the SLP runners. They are already 2 inches siamesed on the plenums side and can be fully gutted out with time and effort.
Mine have been opened up more and ported 3inches intot he runner. You'll see more top end HP and lose a bit of low end torque.
Old Dec 3, 2003 | 11:54 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Yeah - the SLPs are a good buy. $250.00 about and with caution and skill they can actually be siamesed far enough in to create a much wider powerband than TPI is known for. Almost akin to the LS1 runners killer midrange/topend.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
