what do u think of this combo?
Old Dec 7, 2003 | 06:49 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
tell me waht u guys think of this combo for my 67.its going to be a 383 stroker motor.eagle cast stroker kit with -5cc flat tops.heads are going to be afr 190's(not sure if i should go with 74 cc or 64 cc chambers let me know on that one)i have a few cams that i am looking at one is the lunati hr11 specs are @.050" dur intake:226 exh.234 lift @valve is intake.530 exh. .530 lobe sep 112deg. dd200 says 506ftlb@3500 rpm and 429hp@5000 rpm.now the other 2 cams are also lunati specs are pretty close to this one.this is going to be a tpi motor(ported out)and a t56 trans.this car will never see track time so i probably won't rev it past 5000rpm anyway.i know dd2000 is optimistic but what should i expect out of this combo in real life at the wheels?also looking to get about 10:1 compression.this is a HYDRAULIC roller cam by the way.let me know all of your opinions good and bad. i really want a killer street motor.also i have an accell dfi i am going to use on this. also large tube headers with flowmasters.
Old Dec 7, 2003 | 07:51 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
That cam is too big for a stock TPI, ported or not. If you really don't want to rev much past 5000 rpm, check out the LPE 211/219, it works great w/ TPI. Otherwise, I really wouldn't go past a 220/220-ish cam if you plan on keeping the TPI. A 226/234 cam will want to make power WELL past 5000 rpm, prob better to 6000-6500 rpm actually.
Old Dec 7, 2003 | 07:53 PM
BuckeyeROC's Avatar
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
