Tell a 305tpi from a 350tpi
Old Dec 9, 2003 | 09:29 PM
FlyRideZ28's Avatar
Is there any way to tell the difference between a 350tpi and a 305tpi by looking at the engines...any info would be great? guy told me he swaped 305tpi for 350tpi...and wanna see if he is tellin the truth..
Old Dec 10, 2003 | 09:28 AM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
look at the vin number on the engine...u should be able to tell from that...also stamped behind the flywheel (u know u want to take the time to do that ) it says 5.0/5.7 so i am told...or pull the heads off and measure the bore size...the vin number is the best bet...
Old Dec 10, 2003 | 06:26 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
How is looking at the VIN # going to tell him weather it is swapped? All that will do is tell him what the original engine was. Yeah it would help if it was originally a 350 car but I'm guessing he is wanting know if it is a 350 with it originally being a 305.
Old Dec 10, 2003 | 08:02 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
yes i understand...i mean the number cast on the engine...obviousy not the vin number of the car
Old Dec 11, 2003 | 09:10 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Easier way is look at the sticker under the hood, its all emission info and its says 5.0L or 5.7L.:hail:
Old Dec 11, 2003 | 09:12 PM
Dr. Suess's Avatar
Car: 1986 Chevy Camaro IROC-Z
one problem i know i dont have this sticker and i dont know if mine is 305 or 350 either it really pisses me off come summer i am putting it on a lift to get the engine vin
Old Dec 12, 2003 | 09:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Rear of block top drivers side, the bell housing mounting flat area. Will have cast in in big letters either 5.0L or 5.7L.
May need flashlight and some cleaner to read it.
RBob.
Old Dec 12, 2003 | 02:14 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If the seller told you he swapped in a 350 then 99 44/100 % of the time its a 305. Sorry your to late to worry if its a 350, you are stuck with it (whatever it is ). Did you ask for any paperwork or invoices????
Old Dec 12, 2003 | 11:31 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Re: Tell a 305tpi from a 350tpi
If you have to ask, it's probably a 305.
Old Dec 15, 2003 | 02:44 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
It won't say 5.0 or 5.7 if it is an older block. Just look at the 7 or 8 digit number on the back of the block on the drivers side just above the bellhousing. Go to any GM code website and plug in that number. The emission sticker will be of no help whatsoever because the motor may have been changed but the sticker would not have.
Old Dec 15, 2003 | 02:51 PM
DJP87Z28's Avatar
More 305's being sold as 350's then GM installed in 3rd gen cars.
Old Dec 15, 2003 | 09:33 PM
MikeS's Avatar
See www.mortec.com for casting number information and pictures of locations.
We could always pull the heads off and measure it up!
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
rdog30
Apr 6, 2001 07:07 PM
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
