EGR Block off
Old Dec 16, 2003 | 06:08 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
EGR Block off
Hey all I am in the process of building a 305 in my daily driver Convertible. I am using the L98 Vette heads #113 with no egr. I have no emissions so I need to know where I can get a block off plate. I am running the stock prom, will I have any problems with it.
Brian Felts
Old Dec 16, 2003 | 09:37 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You can make one out of steel or aluminum. TPIS sells one out of aluminum for about $8 if I remember correctly...
Old Dec 17, 2003 | 09:26 AM
MdFormula350's Avatar
i am pretty sure stock computer, with no egr will yield in the SES light being on all the time, so u might need to get someone to make you a new "stock chip" with no egr.
Old Dec 18, 2003 | 03:12 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I had an old fuel pump block off plate (you know, the one that goes over the mechanical fuel pump location on the block) and used the EGR gasket as a template.
Cut it out, drilled a couple of holes, a little sensor safe silicone sealant and bolted it on.
It's been on over three years now - of course I did have the EGR turned off in my PROM so no SES light.
Hope this helps.
Jake
Old Dec 19, 2003 | 09:20 PM
PSYKOTA's Avatar
Car: 2000 WS6
With removing the EGR, did any of you experience detonation, or any other problems?
Old Dec 20, 2003 | 01:46 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
you can just make one out of a piece of metal. THats what I did. Im going to have it powered coated black or red to match my other pieces.
Old Dec 20, 2003 | 04:53 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Why? You can't see it anyway with everything installed!! That's why I wonder why TPIS bothers with its polished aluminum one, what's the point?? Whatever floats your boat...
Old Dec 20, 2003 | 05:02 PM
Originally posted by 92 zzz28
Why? Whatever floats your boat...
True my friend!.....and that floats mine boat!
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
