Differences in Throttle Bodys?
Old Dec 22, 2003 | 02:45 PM
Mrfixit's Avatar
I want to convert a (actually convert back to) a TPI on an 89 350. I have everything except the throttle body. Will any year or size work?
I want to convert it to speed density, does that make a diference?
Thanks for a lurker,
Roy
Old Dec 22, 2003 | 08:47 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
All factory TPI throttle bodies are the same size. Larger after-market TBs are avaliable. It's debateable if the larger ones help much, especially if the remaining induction pieces are stock.
AFAIK, any year TB will work.
MAF, MAP, throttle body could care a less.
With a MAP however, you can install a cool looking K&N airfilter right onto the TB.
Old Dec 22, 2003 | 10:49 PM
My86TransAm's Avatar
And suck all that nice warm radiator air into your engine....pfff....yeah right....
Old Dec 22, 2003 | 11:27 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
85-92....the Throttle Bodies are interchangable...but....you might have to change the throttle cable. I have an 85-88 style on my 91 Z28 (52MM BBK), and I had to change the thottle cable for it to work properly. 85-88 and 89-92, the throttle cables attach differently...
Old Dec 23, 2003 | 12:23 AM
cdartz's Avatar
I believe you can't use the earler style TB with the later style plenum unless you drill the hole that the later plenum lacks for the IAC air to pass through. The later TBs route the air differently. The older plenums have a hole between the throttle bores that the newer ones don't. You can however use a newer TB on an older plenum. If I've explained this wrong then someone feel free to correct me.
Old Dec 23, 2003 | 06:33 AM
Mrfixit's Avatar
Originally posted by cdartz
I believe you can't use the earler style TB with the later style plenum .... You can however use a newer TB on an older plenum. If I've explained this wrong then someone feel free to correct me.
When you say "early" or "late" style, are you referring to '92 and older vs '93 and newer?
Additionally, is there any difference between and TB from a 305 vs 350?
Thanks for the great info guys,
Roy
Old Dec 23, 2003 | 07:54 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I didn't say it would run better, it just looks cool!!
In 84-85 the GM execs were planning on dropping the 350.
At the last min, they changed their mind and decided to keep it. No perf FI system was avaliable for the 350, so they used the 305 TPI sys on them.
Point is, the 305 and 350 TPI hardware are exactly the same except for the larger fuel injs on the 350's.
Humm, I was not aware abt the different IAC passages.
I'm assuming the "older" and "newer" refers to the 85-88 and 89-92 systems respectively. 92 was the last year for the TPI.
Old Dec 23, 2003 | 09:20 PM
Mrfixit's Avatar
Thanks for clearing that up and for helping to answer a novis' questions.
Roy
Old Dec 24, 2003 | 12:23 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Earlier plenums got EGR air through the small tube on the runners from I believe the drivers side runner. Later year plenums have a hole at bottom of TB for EGR air. Can use any TB for either, just have to use TB gasket for that year plenum. The TPS adjustment is also slightly different between years. IAC air flows through the TB on both models.
Old May 21, 2012 | 02:15 PM
DBRjeep350TPI's Avatar
Re: Differences in Throttle Bodys?
Interesting... I am running into problems on my TPI setup i installed on a 327 block. The IAC passages and TB's you are talking about. I am looking at my setup and it looks like a 85-87 unit w/9th injector, but blocked off. Yet the TB has the nipple on the underside for the tube to the EGR. I dont see any port coming off the runners...
my question is by the sound of it I have a pieced togeather unit. I dont know know what year of IAC housing I have is there anyway of telling? And if the nipple off the underside of the TB is for 90-92, that is what I might have. I am curious of what IAC motor to use???? or if there is any diffrence between 85-88(AC1) and 89-92(AC16) IAC motors except the part number and price?
Old May 21, 2012 | 08:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by DBRjeep350TPI
the TB has the nipple on the underside for the tube to the EGR. I dont see any port coming off the runners... ?
On a TPI TB ,pass side you have top to bottom
PCV supply air to pass side rocker cover
a vac port for tank purge
and on the alum casting underneath that the IAC mounts into ,the spigots for coolant
There is also a small vac port under TB on drv side
EGR does not go to TB on any year;is by internal passage,
up the pass side runner and in the passage cast under the plenum to exit
through the 2 holes BEHIND the TB
See
http://www.hotrodlane.cc/Streetstories/choosingtpi2.htm
http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
