ZZ4 qwestion
Old Dec 24, 2003 | 03:48 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
ZZ4 qwestion
will my stock 89 tuned port intake bolt strait on to a zz4 fast burn crate motor
Old Dec 24, 2003 | 03:55 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
The Fasturn heads have raised intake ports the same as the vortecs and they won't work with your stock tpi setup.
Old Dec 24, 2003 | 04:09 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
how about the zz4 355 non fastburn?
Old Dec 24, 2003 | 04:12 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
You would have to elongate the two center bolt holes on each side of the intake to make it work on the base ZZ4. The ports will line up.
Old Dec 27, 2003 | 11:59 AM
ULTM8Z's Avatar
Fast Burn heads have an intake flange capable of running either a Vortec or a conventional cyl head. As such, it has dual bolt patterns- Vortec and conventional. However, the conventional pattern is the pre-1987 one, in that the holes are perpendicular to the flange. Your 1989 manifold has the revised angle on the four center hold down bolts. Like gixxer9 said, you'll have to elongate those holes to make it work. I believe Edelbrock has a tool to do just that.
Old Dec 27, 2003 | 12:49 PM
Blackroc86's Avatar
Car: 1986 Iroc
A standard chev sb intake will not work on Fastburn heads. Yes they are drilled for both but they standard intake runners won't even cover the intake ports on the Fastburns. When the HSR first came out I tried to put one on my Fastburns but when set in place you can still see about 1/4" of the intake port on the heads above the outermost part of the intake.
You must use a vortec style intake on those heads.
Old Dec 29, 2003 | 04:56 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
Like I stated, the BASE zz4 (l98 style heads), can use the standard intake manifold, but the center bolt holes must be elongated to be compatible with the bolt angle. Fastburns are just fancy vortec's, therefore, using the vortec pattern.
Old Dec 30, 2003 | 04:29 PM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
I have a ZZ4 350 CID and did not have to elongate the center intake bolt holes. The heads on a ZZ4 are L98 style aluminum heads from the Corvette.
Old Dec 31, 2003 | 01:59 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
so you bought the zz-4 crate motor and your stock tuned port intake fit on it wit no mods?
Old Dec 31, 2003 | 02:08 PM
jmiller's Avatar
Yep, no mods needed.
Old Dec 31, 2003 | 08:30 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
sweet!
Old Dec 31, 2003 | 08:53 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
just get it..... dont think about it just hit submit
Old Jan 9, 2004 | 11:57 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Hey Jmiller,
I know I am late getting in on this but the ZZ4 does not use L98 corvette heads. The corvette heads are 64cc, the ZZ4 has 57cc. I have both motors. Just FYI
Cheers
Richard
Old Jan 9, 2004 | 12:06 PM
jmiller's Avatar
88gta305:
I thought they were the same. Years ago when I bought my ZZ4 from Scogin/Dickey, that's what they told me. Could the 58CC be the only difference???
Old Jan 9, 2004 | 12:18 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
what other crate motors pusing 325-450 hp can i find that i can stick my stock tuned port on without any mods?
Old Jan 9, 2004 | 01:03 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I believe that aluminum L98 Corvette heads are 58cc.
Old Jan 9, 2004 | 01:10 PM
jmiller's Avatar
I agree with you, I know their 58CC, but I also thought they were Corvette Aluminum L98 heads. That is what was told to me by Scogin/Dickey when I bought my ZZ4. It also is described in the GM crate motor catalog as having Corvette L98 alum heads.
Old Jan 9, 2004 | 01:41 PM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
They are L98 Corvette heads, I promise.
Old Jan 9, 2004 | 02:44 PM
gixxer9's Avatar
Car: 86 IROC
Engine: 6.2
ROH IS RIGHT.... IF THEY'RE ALUMINUM, THEY'RE VETTE HEADS.
Old Jan 9, 2004 | 03:09 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
ALUMINUM L98 heads (CORVETTE) = ZZ4 heads = 58cc
IRON L98 heads (FBODY) = probably the 64cc version
Old Jan 9, 2004 | 04:00 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I would suggest that you buy an intake rather than different heads. The "Fast Burn" heads are good for more power than the ZZ4 cam can put out. The cam will only pull "hard" (emphasis on HARD) to 4800-5K with the stock stuff, actually I always had the Edelbrock base with the ZZ4 cam..... You will gain a minimum of 500 rpm of MUCH HARDER pull with the aftermarket intake and runners. In fact, it will pull much harder from 4500 rpm on.
GM and Street and Performance both make Vortec/Fastburn TPI intakes. I would go that route first. Later you could add 28-30# injectors, SLP runners, 52MM Throttle body and a much larger fuel pump. I do not reccomend the Buick GN fuel pump for that motor or even a stock motor. No one I know has had a lot of success with it. Most guys I talk to with fairly stock motors are finding the 286 LPH Mustang (UGH!!!) fuel pump does wonders for their acceleration. I am changing my fuel pump later on myself. I just don't have the time to do it right now (Do have a LARGE Bosch pump).
Bottom line: Plan well, take your time, Do it one step at a time if money is short, don't get too carried away and have to redo everything twice or thrice......
:werd:
Old Jan 10, 2004 | 06:06 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Yea money is real tight so i am trying to build the cheapest setup on paper that will upgrade my power.does anyone know about what setup would be perfect for power and price i want to stay tuned port. please post recomendations of engine/iduction/exaust combos 4 as cheap as possible.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
