SLP runners help me?
Old Jan 16, 2004 | 11:07 PM
87350IROC's Avatar
Car: 87' IROC
current setup:
L98 355
Iron L98 heads, valve job, minimal porting
ZZ4 cam
ported plenum
hooker headers and catback
Do you guys think the SLP runners will help with my setup? From what i've read they may actually benefit since i have the zz4 cam. This is also assuming i would siamese them and port and siamese the manifold and plenum.
JP
Old Jan 16, 2004 | 11:54 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
If you siamese the upper plenum & the lower plenum and port match everything then you will see some very nice gains.
Any idea what peak hp @ rpm is? With a good job you should see around about 500rpm bump to peak power, and a widened powerband with increased power going into and coming out the sweet spot.
Old Jan 17, 2004 | 02:09 AM
Morley's Avatar
Ditch the stock manifold, you need a better flowing manifold to take advantage of those runners.
Old Jan 17, 2004 | 02:41 PM
87350IROC's Avatar
Car: 87' IROC
Interesting, peak right now is about 4800 rpm. Yea, i figure a better manifold would help alot. Thanks guys.
Old Jan 17, 2004 | 03:32 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
A stock manifold will flow pretty good with extensive siamese and port work. However, an aftermarket manifold with the same port and siamese effort will easily outflow a stock piece.
It's up to you. YOu have the money & time to buy an aftermarket base and work on it? Or would you rather work on a base you already own?
Old Jan 17, 2004 | 05:01 PM
Morley's Avatar
Think of it this way....he could drive the car still while he is porting the runners & manifold, then just have to port the plenum when he takes the car down for the swap. Plenum porting is a snap, takes hardly any time at all.
Old Jan 17, 2004 | 07:58 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I understand the trade off. I was just posing the choice to him, because he is the one doing the work
Old Jan 17, 2004 | 08:51 PM
87350IROC's Avatar
Car: 87' IROC
I'll prolly end up buying a new base. I like less down time and better performance. However its also a lot of money for an LTR setup.
Old Jan 18, 2004 | 12:39 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Make sure to siamese another 1" or so into those SLP runners.
Port match everything up, and that intake will be really nice.
Old Jan 18, 2004 | 11:36 PM
F-Body Tim's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
You should notice a huge gain because the other mods you have. i didn't get that much of a diff. because all i have is K&N on a 305.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
