Super Ram
Super Ram
Will the Super Ram plenum and runners bolt right up to the sdpc vortec baseplate? I want to get the sdpc tpi vortec 350 crate, and am considering this intake. Would that setup flow better than a stock tpi plenum and slp runners? If it dominates the stock plenum, etc...then I'll go w/ Super Ram. Does the linkage and everything fit the same on it w/ a stock throttle body? $800 for a plenum and runners seem spicy, considering I could probably find a whole 90-92 map tpi car for $1200 and use that whole tpi intake!! lol
Any help would be kewl.
Thanks!
Thanks!
Oh yeah, forgot to mention, all I have to do is pass the sniffer for emissions, so I DO need EGR. My main goal I'd like would be around 350 rwhp. So, w/ the 359 horse sdpc tpi crate, I'd need to bump it up around 450 or so. If I'm like 320-340 rwhp, that's kewl too. I'm not going on the track or anything, just a street car that wants to dominate the folks around here
It will nolt bolt up out of the box.
It will perfeorm better than any LTR combo, all day long.
https://www.thirdgen.org/techbb2/sho...=superram+bolt
OMINOUS: Just read the thread, seems like a lot of work. The only thing I wouldn't like doing is buying the sdpc crate, and then tearing into it to port/polish, etc...What intake are/were you running on that tpi engine? If I were to use the stock tpi from a 350, what would I be looking at? $3500 or so for the crate, then chopping into it, just doesn't seem worth it to me. If I can get close to 300 or 350 rwhp, then I'll just use the stock intake. I'm not running it at the track, just want to kill the street cars.
Thanks for the help!!
Car: 1990 Iroc-Z
With a stock TPI LTR setup that SDPC engine will probably make about 280-300RWHP. The beauty of Vortec and TPI LTR is not HP... it is TORQUE. Torque is what you want for a street car and vortec heads + tpi ltr = torque.
Ok, w/ that horse and torque, how'd it put up to stangs, cobra's, ls1's, **** burners on the street? Around me, in the summer, etc...all these **** burner guys are around, and couple of built up stangs, stock ls1's, etc....I want to smoke these guys...keep in mind it's light to light, etc...no track type racing...
Thanks!
Thanks!
Thanks!
Thanks!
Yes, this upcoming summer, I plan on getting a bunch of suspension upgrades...bilstein Shocks/Struts, Spohn LCA's and Relocation brackets, Spohn Torque Arm, front end rebuild kit...Moog springs (don't want the harsh STIFFNESS of the Lowering kits), Firestone Firehawk rubber...that should make me stick any power to the ground very nicely...
Yeah, I'd like a little more power to reassure some wins...Any other mods I could do w/ TPI that would give more power? I really don't like the idea of tearin' into that new crate...the other crap, I could get from junkers, so I wouldn't mind doin' stuff to it.
ZerotosixtyV8: Were you giving that rating considering headers, exhaust, slp runners, etc. etc.? Basically at max w/ that engine and tpi, what would I be looking at getting? What are the "reasonable" mods I could do to boost the 300 rwhp by a little ways?
Thanks again for the help.
You might want to look into a differnet crate motor and a different intake.
There is no way in hell the SDPC Vortec crate with any LTR setup will put down 300rwhp.
Aint gonna happen.
Aint gonna happen.
Well, I don't know who to believe...some people said it's very possible, others say no. I want to spend about the same money for the sdpc vortec, possibly very little more. I need to be 100% Emissions legal (sniffer only). I have a '90 Firebird w/ a 3.1 mpfi now. I want a direct bolt on w/ the less hassel the better. I picked the Vortec tpi b/c it's basically the L98 w/ Vortec Heads, better cam, etc. Plus, w/ TPI, my wiring can all stay intact, and I won't have to gut so much, etc. If there is a better solution, please let me know, but so far, I'm getting misdirection from a lot of people. I'd like to stay Fuel Injection too, as I'd be more likely to pass emissions, plus, my wiring is already there.
I havn't converted over yet, but it'd be pretty easy to do it. I already have a 7730 ecm, so all I'd need is the chip. Not many other cost effective/fuel injected ways to do this setup I'm thinking....
I don't know about LT1's, etc....I don't want to be notching in my K-Member and all that stuff...plus, I don't know where to get a brand new LT1 motor, or LT4, etc...Also, how would the wiring route on that? Same setup? ECM on passanger kick, wiring through the fender, then distribute accordingly? Engine bolt up the same as a L98? Would it use the same Trans, or would it need a 4LE? I want to stick w/ Automatic. I'm grasping at straws as there arn't many ways that would bolt up as easy as the tpi crate (l98 block) I'm assuming.
Ok, well, what's a direct bolt on crate/injection system that will go right in like an L98 and give the power I'm looking for? I also picked the tpi crate b/c I can find a parts car for cheap, and get all the pullies, etc. that I'd need. Not sure about the LT1's, etc. What other suggestions are there?
It doesnt matter really what intake you sit on the motor, all the junk is going to bolt up just the same.
I dont buy crate motors so I cant help you out there, but you might want to search the net for the best crate you can find that is a non Vortec motor and stick a HSR atop it.
Or maybe buy a shortblock and then score the rest seperately.
So, the TPI Induction craps out at what power range? Zerotosixty said the Torque that TPI puts out would be great for the street. I don't need a top end fueler, b/c I'm not doing "that kind" of racing. Basically just messin' around on the streets...maybe the occassional drag. So, high 12's don't sound so bad. Does anyone else agree that the sdpc crate w/ tpi would get 300 rwhp if not more w/ what kind of upgrades/tweaking, etc.?
TQ is a whole different conversation. It will make gobs of TQ. But if you have an expectation or requiremnet of 300rwhp in mind chances are you will not reach it, thats all.
It will be very fun on the street, light to light. Modded LS1 cars will take you down all day long though, light to light. On the highway you will get beatup by both modded LS1 cars and modded Stangs. You should take down most of the ricers no matter what the situation.
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
3750 LBS GTA(with driver), fully loaded and full weight runs 100+MPH in 1/4 mile with some tuning left in her.
3750lbs@100.5MPH = 280-290 RWHP.
That's with stock L98 cam, completely stock runners and plenum, sstock throttle body and no cold air package.
Once I install my ported plenum & runners, 52 MM TB and SLP Cold Air package, here comes the bench racer in me, I estimate 103-105 MPH in the 1/4.
3750lbs@103MPH = 320 RWHP.
Very doable in my opinion...all this with the stock cam.
By the way on the street(light to light) I already kill LT1s and make a race out of it with LS1s.
My combo in a lighter Fbody (3300lbs without driver) would be approaching 110 MPH and mid 12s.
Have you read this thread yet?
It has been around for some time now.
Mike runs low 12s and puts 300hp to the rears.
He is running a 383 though with worked over heads: bowl work and decent valves.
Engine: 3.0
BTW, I assume you are talking about Mike Crews....he does those times with a 1.66 60ft...that's explains his ET, but his MPH are still low, only 108...that's inline for the HP he's making, but in my opinion he should be making more power than that.
I think the L98, modded, will still be the cheapest, easiest route for me. I don't have a shop, or giant garage. Also, I don't have a lift. So, redoing this thing is STILL difficult, but I think the L98 either crate, or worked over stock, will be less headaches for me. Even 290 or so at the rear should be very good, w/ that amount of torque. I think it will be MORE than fine for street use. Thanks for the considerations on different idea's though. Seeing as how I don't have a set "requirement", just wanting to go good and have ***** on the street should be easy to meet w/ the L98.
Thanks!!
Thanks!!
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Let me shed some light on this......I have the GM 350 HO Vortec motor w/TPI intake. Compared to the L98(RIP).....Well there is no comparison. This damn thing pulls all the way up to 5000 rpm before you feel a hint of power loss. The run that you can compare is the one I had with a 2000 LS1. He has the SLP air lid and running with open exhaust out the back. He was infront of me and we were doing about 45ish...He gets on it (so he had a good car on me already) and I follow. He SLOWLY pulls away until we let off at about 120...(LONG STRAIGHT ROAD TO THE PLANT) I would say he was about 2 1/2 cars on me (thats counting the car he started with).......so we do the math and he pulls about 1 1/2 cars on me. Now if we could have gone from a stop, I would have raped him out of the hole and he probably would have come back and beat by 3/4 to 1 car in the Qtr.
the moral of the story is that the LTR are good enough for what you are looking for.
I do appreciate the info. about the super ram though.....I was thinking about getting one of them.
Later
Later
1fastformula: So, you think the L98 is a rip? Even referring to the sdpc Vortec tpi crate? Sounds like a good strong engine for a street car to me. Your story sounds very reassuring of the potential of the tpi induction.
Thanks!!
Thanks!!
https://www.thirdgen.org/techbb2/sho...threadid=84340
I forgot the link, i was hoping the original poster was in the know of the Crews thread.
300rwhp is about the puke point of the LTR setup, maybe good for a little more but most often not.
Thanks!!
Thanks!!
Later
that torque, if you can hook it up, makes up for the top end loss to an extent, you are capped at 12s with a TPI 350. there comes a point when you need the RPM to make HP to get you into the 11s and 10s, if you so desire to run them
Hadn't realized more people replied to this thread. Yeah, sounds like a very good idea then. Do you think I'm better off finding an L98 car, and just rebuilding it? I know a guy that builds drag cars and won many awards. He can probably do whatever is needed to squeeze anything out of that block. Or, just go w/ a crate, and settle for what's there? Crate is less hassel, but it's hard to find a good combo one for under $3500. For what " zerotosixtyV8" said, $2k for parts, and probably get the car for $1500 or so...and that's that. Do you think a rebuilt L98 is just as good as the crate, in terms of lasting long, etc.? I mean, a crate, if it gets worn, there is still meat to bore out. More than likely, if I find a junker, it'll be bored and that's it, or if unlucky, it's already maxed out. So, what are my alternatives going THAT route?
Forgot to mention, for my application, even if I'm capped at low-mid 12's, that should be more than enough on a street car. 400+ CHP and TQ sound very good for a 300-350 rwhp engine. Also, rebuilding a 700R4 from the junker...would it be good, or just go for a Pro-Built one already w/ Corvette Servo's, etc.? New is always easier, but if I can save $$ and still be just as good and long lasting as new, I'd go rebuilt...
Thanks a lot!
Thanks a lot!
From all your responses so far it doesnt seem that you are willing to take all those measures.
As for the trans, if you dont have a good core a junkyard rebuild is not always the best option, you have no idea of the history.
Some guy here in AZ has a Iroc for sale cheap, I have no idea of condition but it might not be a bad way to start. Seems like your way behind the curve with what you got Vs. what you want.
I was giving a rough estimate of my "300-350" quote on rwhp. Ok, so SAY 280-290 rwhp. If you have that WITH 400+ TQ, it is still good for 12's, so, off the line or around the street, you'll have PLENTY of power for a street car, in my opinion. Maybe it won't make a good dragster or track car, but I'm thinking it'll be plenty to show up guys on the street.
Do you agree with that calculation or not?
I have seen cars in the 255-260rwhp range trap 101 at similair race weights, slightly less though.
With the L98 cam and heads might I add, untouched heads, HSR intake though.
I'm not talking about stock heads, cam, etc. If you used all beefed up parts, your saying you still cannot get 300 rwhp just by keeping the LTR intake? Sdpc said they dyno'd it at 310 rwhp by doing some tuning, etc. So, who knows what now? lol, too many opposing answers.
That is much more realistic.
There is huuuuuuuuge difference between 300 and 350, and you will never get a crate Vortec motor close to 350, not even close!
heads, cam, intake parts, headers, exhaust, converter, AL shaft, fuel system, CAI, etc.. Oh and dont forget tuning.
This is not new information fellas. Kinda common knowledge.
Ok, so say it was all beefed up, and you switched to Super Ram? Would that magic 300 # automatically rise? Or, what would you get more out of the same exact setup, just switching to Super Ram?
Engine: 3.0
A tracked prepped car can easily shave off 200 lbs, thus requiring less HP to make equivalent MPH....
I think 300 RWHP is attainable with a TPI setup, maybe with aftermarket runners and base though....
How much less? I happen to have a heavy 3rd gen car...some weigh as little as 3300lbs....
The real key to the speed was that there was damn near 100lbs removed from the drivetrain:
From the front to the back
~22lbs=Yank 9.5" converter
~6lbs=LS1 AL shaft
~60lbs=front skinnys, rear DRs, on lightweight drag rims
The car however was full power with AC, GFX, etc... Z28 Trim
The benefit of reducing rotating weight has multiples of impact over the benefit of cutting sprung weight.
Engine: 3.0
3750lbs@100.5MPH = 280-290 RWHP because this was done with absolutely no weight reduction anywhere.
But I beg an answer, why dont you lose dome weight on that pig?
Engine: 3.0
No way, 290rwhp should be pushing at least 103 if not closer to 105, maybe more
LS1 Camaros and Firebird (automatics) run bone stock 104-106 MPH. They weigh less than MY GTA and they dyno 300+RWHP pretty regular.
So how do you figure that a heavier car would require less RWHP to acheive that MPH? All the MPH/HP calculators available back up my numbers, where are you getting yours from? Go to www.prestage.com and click on the car math link....then play around with those numbers.
Because my goal isn't to go as fast possible, it is to build a well balanced street car that can keep up with the newer cars on the roads today. I can't really shed much weight from it unless I start removing things, and that I won't do.
My car handles better than it did original, idles like a stock car, is quiet and aside from the headers looks bone stock. It runs consisent 13.8s on my everyday street tires, and once again the bench racer in me predicts 13.5s or better with 103-105 MPH once the last set of upgrades to the intake system is done, all this and still maintaining the stock look and full weight.
I think w/ all the work that is involved to fit Super Ram on that Vortec baseplate, your better off sticking w/ the LTR design. I mean, 500 more rpm, I don't think it's really feasible to do for just a street car. 290 or so rwhp, w/ a huge amount of TQ, I do think when backed up w/ everything else in the drivetrain, you can smoke many street cars. I can't see how I could personally go wrong w/ that engine. Remember, I'm not doing 1/4 mile runs, or drag strip type deals. Just the occassional, "Who's better from the light" games.
I have a well Ported Super ram and I installed it on my Iroc with stock manifolds, and I picked up a good amount of hp, the top end was much better. My build plan is a zz4 sb with a 236/242 with the vortec heads slp tri y dual cats into a mandrel cross flow master, And Dyno 2000 shows over 440hp
Basically I went backwards on my build up. I bought the Super Ram the Cam the headers the Vortecs and manley springs retainers and screw in studs and guide plates.. When I should have Just Bought a ZZ4 block.. If you have tpi now I say just use that and build pan to manifolds.. Not Super ram, cam heads etc.. Just my .02 and Story..
BrandenCali: Thanks for the info.
So, your saying a ZZ4 would be a better plan, instead of messing w/ the L98 or tpi crate? I have a 3.1 mpfi, so, I can really go either way w/ this. With the ZZ4 crate, can I use the whole setup that the L98 uses? ie, Brackets, Clips, Accessory Pullies, etc. etc.? Basically saying, would the ZZ4 bolt right up as if it were the original L98 engine? Complete install, wiring, etc...all the same? If that is the stronger engine and will give more power, maybe that's my best bet...
no green
Jan 9, 2016 09:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
