vacuum check
Old Jan 23, 2004 | 08:16 PM
grndmasnightmar
Guest
Posts: n/a
vacuum check
ive looked all over but i cant find an answer how do i check engine vacuum in my 89 tpi 350?
Old Jan 23, 2004 | 08:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
When you say engine vacuum, could you be a little more specific as to the areas you would like to check.
The Trickster!!!!!!!!!!!!!!
Old Jan 23, 2004 | 08:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Look on the pass side and you'll see a brreather tube from the plenum to the valve cover....the plenum vacuum should be sufficient for what you want.
Old Jan 26, 2004 | 05:26 PM
grndmasnightmar
Guest
Posts: n/a
i dont know if i have a leak somewhere i was just curious on how to check my total vaccum. dont they have guages for this or they doent work on a tpi. ive just heard of people saying there vaccum is like so much per squae inch. whats this all about?
Old Jan 26, 2004 | 05:36 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
You can check vacuum from many sources, the FPR port, brake booster port, or PVC. The vacuum gauge will give you a reading in psi, should be around 18psi on a stock engine. It is tested at idle.
Old Jan 26, 2004 | 09:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Engine vacuum is measured in...vacuum, not pressure...most gauges read in inches of Mercury, i/e in/Hg, psi is a pressure rating.
Old Jan 26, 2004 | 09:10 PM
Haha, yea, Mike is definately right, I dunno wtf I was thinking. Boost is measured in pressure.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
