GM 96+Vorctec heads L31 bolt on?
Old Jan 29, 2004 | 01:30 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
is it bolt on or port and holes and bolt angle wont match?
Old Jan 29, 2004 | 01:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The heads bolt right up to the block, your intake won't. The bolt pattern & the ports are different. You need a Vortec specific intake to run those heads.
Old Jan 29, 2004 | 02:00 PM
FOX-GTA_89's Avatar
witch intake???
a gm casting part or an after marcket?
Old Jan 29, 2004 | 02:06 PM
vwdave's Avatar
For a TPI setup, you need a SDPC vortec base.
Old Jan 29, 2004 | 02:14 PM
FOX-GTA_89's Avatar
sdpc
on yeah sdpc but GM made or not???
where i can have one???
is it a better idea to simply ported my stock heads why should i go for that?
Old Jan 29, 2004 | 06:42 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
the vortec/tpi setup is a nice setup. I managed to get my heads for 200$CDN so even though the intake was $400USD overall my investment wasn't that much to get my car solid into 13s.
Now with the heads and better flowing base I have room to grow. I can see my car running very low 13s with some more inductuion work.
Porting your stock heads doesn't give all the advantages the Vortecs have, such as fast burn combustion chambers,high port velocity due to runner shape and size, and good swirl. Making power isn't simply a flow #, but how they flow and how well the can burn the mixture.
FYI, If go don't go TPI GM sells an intake for carbs with the Vortec bolt pattern.
Old Jan 30, 2004 | 03:29 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Get the heads mangafluxed before you do anything else if they are used. A lot of used Vortecs are cracked because of the intake design.
To use the TPI on a Vortec you need the SDPC base, which is thier own patented design. GM had nothing to do with it.
Old Jan 30, 2004 | 09:12 PM
FOX-GTA_89's Avatar
Mini ram vs. SDPC
the SDPC package with the vortec heads cost aprox 400+600
and the mini ram cost 200$ and a stage 2 porting job on stock heads is 400$+200 fuel rail witch one give the best performance for the price???
Old Jan 31, 2004 | 03:07 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Re: GM 96+Vorctec heads L31 bolt on?
scoggin dickey makes a TPI manifold that mates to vortec heads for 400 bucks, and an egr kit and arp bolts for an extra 100 bucks total, of 500 bucks
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
